R Type 2 stuck inputs
5,332CR
Fantazia2 said:
I think this is how the array is laid out. Pleas excuse the dodgy MSPaint handiwork.
The original array wont have resistors at R2,4,6&8 ( if I'd did, then a multimeter would read about 2.5k when testing pins 1 and 2 (as there'd be resistors in parallel).
I think it's like this:
They do exist, just not sure which shelf you find them on :-D.
But, yeah, by putting in resistors and using the new array, you'd make the equivalent of your diagram (which is close enough, although the pull-up resistance is halved by having twice the resistors). I still think it should've worked when Virtec put pieces of wire in those 220 ohm locations though... John Bennett2018-01-26 08:01:01
Fantazia2
2,246CR
You might be right but going by Virtvics measurement of an original array, he did a measurement between pin 3 and 4 and got a resistance 9.2k so looks like going through two 4.7k resistors, so it could be laid out like your diagram but instead of the 4.7k being on pin 2 it would be on pin 3 instead.
Would ideally need a few more measurements to confirm the original layout.
5,332CR
Unless I'm reading the wrong post, between pins 3&4 was 9.55k, which'll be 4.7K + 220R + 4.7K
I'm pretty sure it won't have pull-ups on every leg as you'd get much lower readings due to all the parallel paths and it wouldn't serve any purpose (as it's a resistor network intended for the dual purpose of pulling-up and having a series resistance).
Edit: -it's not such a big deal anyway - as the link proves, you can get away with a 4.7k pull-up array and 220 ohm resistors between the pins. The only difference the extra pull-ups make is that they'll halve the effective resistance, so it'll draw twice the current from the microswitch, but it's a negligible amount anyway (around a milli-amp normally)
John Bennett2018-01-26 16:35:59
5,332CR
Ah, sorry, you were questioning which of the 2 pins the pull-up is on. I think I've got it right, looking at the measurements, but I can't see it mattering whether you pull-up before or after the resistor.
Fantazia2
2,246CR
Yes it doesnt matter too much as the repair guy on the link says it works with the standard resistor array and the piggyback resistors on each pair, its just a bit of fun trying to work out how the original part was configured and what it does.
Fantazia2
2,246CR
John Bennett said:
Absolutely
. I just wish I knew the name for this type of resistor network, as you see similar in other games and they would come in handy.
I think they are possibly custom built/ordered ones specifically for the maker of the boards, in this case IREM.
EDIT: Actually Maybe Not Link
This board uses an M Type Resistor Network 8M472J221J
Fantazia22018-01-26 18:52:35
Fantazia2
2,246CR
Yeah my brain totally wasnt working on that one pin 3 would go through the 220 resistor then the 4.7k and then back down the other 4.7k and to pin 4.
5,332CR
The datasheet says M-type is an 'even pin voltage divider'. Can't find much of either on the internet though, suppose they're not in high demand.
Edit: - good find with the datasheet. I couldn't make out the letters to search for it. A bit relieved I got the diagram correct
John Bennett2018-01-26 20:08:13
mish
17CR
To the OP - R-Type 2 is a 2 button game right? Each resistor pack is 4 channel, so if you are really stuck with the resistor cut the trace coming from the current down resistor pack output and run a wire from the unused button 3 or 4 to the down input on the LS244. Then just tie the down input with the button 3 or 4 input.
As previous advice, piggy-backing a LS244 on top of any suspect one will show if that is the problem.
5,332CR
Now the resistor should be sorted, what is the down input at the 74LS244 doing? Is it toggling, or stuck?
If you can pull it to 5V using a resistor (4.7k ideally, or something of a few K), then there's a broken track between the resistor and the 74LS244. If you can't pull it and it's stuck low, then it's the IC (and you might actually not be able to sort it by piggy-backing as it'll drag the new IC down too, although still worth trying too).
Edit: - there is also the filter capacitors in the circuit too - doubt they'll go short circuit, but something else not to forget about too.John Bennett2018-01-26 21:48:58
virtvic
The Cabaret King
21 (96%)
2,013CR
Right - I'm back on this again after recording and editing silly damn podcast (and being ill)
All continuity from the edge connector to filter cap to resistor array to next cap to 74LS244 are ok for all directions.
When the game is powered, I get HI pulled to LOW on my logic probe on the pins on the LS244 except for pin 11 (which is UP) I also get the same HI to LO readings on the edge connector when probed except UP - it stays HI.
I have piggy backed the LS244 with a new one and it has the same result. I am wondering whether to snip the old out, socket and try again, but you knowledgeable lot say it should work?
The IC in question is IC 19 on this Major Title board.
virtvic
The Cabaret King
21 (96%)
2,013CR
Hmm - I just plugged my controller into port 2 of the supergun and started a 2 player game.
P2 controls 'were' working ok, now it won't go UP. It isn't being stuck down though. You can move around ok, but just not up. SAME AS P1 CONTROLS
Pin 11 on the next IC down (IC18) isn't being pulled LO either (all the others respond correctly)
AAAAARGH!
virtvic2018-01-30 16:34:00
5,332CR
Yep. With 1k, it should pull the pin to comfortably under 1V. If it doesn't, then the chip may be knacked and pulling it high.
I had a dip switch input on a Pacmania that wouldn't toggle and it was a stuck-high input to a 74LS.
Also, did you do the diode test with the multimeter on the suspect pins? (Try red probe on the pin and black on 5V and see if they read different to the other input pins).
Just swapping the chip would do no harm if you could do it without damaging tracks.John Bennett2018-01-30 20:44:55
