R-Type - Dead :(
RGP
Meeter & Greeter
2,039CR
Have an R-Type board set that died last October and i've finally got around to being confident to have a look at it.
I have been fortunate enough to borrow another board that does work to single out the offending layer - its the CPU (M72-A-C) board.
I have clock, reset etc that you'd expect.
The primary problem seems to be with the latches on the CPU address/data bus.
There's a signal called BUS CHANGE which controls the 373's and some 244's directions. This is stuck low.
This is noted on the schematic as being pulled up by R19 and also connected to CN3-10B. Following the drawing back, CN3-10B on the ROM board does indeed have a designation for BUS CHANGE but its not apparently used.
It's not the ROM board as that works on the alternate set and the alternate set's ROM board doesn't boot the non-working set.
I'm stuck where I can't find the origin of BUS CHANGE.
My understanding is that it needs to change to HI in order for address lines to pass over the 373's onto the address busses.
I can see data at all the inputs of all the 373's but the outputs are held HI or floating with nothing going on on /OE (pin 1) at all.
Anyone able to help find the source of this signal as i'm sure that's the root problem as why the board isn't starting up.
Thanks.
PaulSwan
ZZZ
1,118CR
It's supposed to be low I think to allow the CPU's DBEN to take effect. Likely on some games if there is a processor on the ROM board it can take it high to disable the CPU bus(?)
~DBEN is as an output of 7N (ALS00) that's made up from the DBEN (uPD70188) and BUF RW (uPD71059). It's active when the CPU is doing something so if you have a CPU that's crashed, halted or not running it may be a symptom rather than a cause. If you have bus activity at the CPU I'd check 7N & 9FH to see if they are bad.
Paul.
RGP
Meeter & Greeter
2,039CR
Hmmm, so what are those uPD CHIPS? the ALS00 seemed to be working as its output was changing but the DBEN signal wasn't changing but BUFRW was.
There is constant activity on the cpu still even though i'm seeing a garbage screen.
RGP2015-07-14 08:29:48
