Raspberry pi loaded memory card
FrancoB
16 (100%)
979CR
Was thinking by the time i unzip the files there will be no space left on my 128gb sd card. Its advertised as 128gb. Bought the card for nothing
It might be wise to post a screen shot of what you've downloaded.
It sounds like you've downloaded the individual zip files onto your 128GB card, you don't want to do that.
Are you using a PC to download the files?
  • You need to move the downloaded files onto another drive where you have at least 128GB plus whatever size the zipped files are, this will ensure you have enough space to unzip the archives.
  • You'll then unzip the .zip files where they currently are (I'm not sure what the file setup you have but often unzipping one file will then unzip the lot if it's a split compressed archive - again, seeing what you have downloaded will help)
  • I imagine this will then yield a single .img file or similar. When you run the imaging software you'll select the .img file and then select the 128GB drive as the target.
FrancoB
16 (100%)
979CR
They are .rar files so you will need software on your PC that can extract .rar files. Install Winrar or 7zip or similar if you haven't got one already. Using 7zip I would then right click on the 001 file and then select 'Extract Here' to extract the .img file into the same directory as the .rar files.
Markitanis
65CR
Ok guys so i unzipped file 001 and it unzipped all the files like u guys said Im now left with an image file. What next guys?
Chihiro
778CR
I've used some really old ssd's out of the skip at work & not noticed any difference between them & much newer nand ones.
