Replacing transformer
tin
673CR
Retrojedi74 said:
Anyway he said when I moved the machine I could of disturbed the capacitors in the power supply and told me to leave it switched on for a couple of days to see if they will build up with power. If that doesn't work then he will come around and have a look on Friday. ??
I've never heard such BS by the way! Leave something that appears not to be working on for a couple of days? No thank you!
Retrojedi74
87CR
Ok well I think I've sorted out the left/right picture problem. Now I need to sort out the picture going down about an inch. I assume it would be vertical something but I think it's best I get some more advice for you guys? Also there now is a very slight rabble to the picture too. Thanks again in advance.
gunblade
9,144CR
the wobble is either the horizontal frequency adjustment on the edge or the ptc component in the degauss circuit is leaky
easy to prove, disconnect the degauss coil from the chassis-its the 2 pin connector to the left of the 3 pin power connector on the chassis
