Replacing transformer
Retrojedi74
86CR
Hi all, I'm hoping to get my transformer replaced as it has stopped working or even maybe repaired if possible. If anyone can recognise what type it is as I'm stumped what type it is. Thanks in advanced fo any advice.
favouredson
Super Star
1,260CR
Have a look inside the case.
The top is hinged and should open if you remove the two top screws.
Check out the earth cable while you're at it...
Retrojedi74
86CR
Well I have checked the earth on the transformer and seems ok? However when I use the reset button on the transformer the I get a boot up noise on the monitor and power goes to my pcb with the leds light up momentarily and then everything goes off straight away.. Any ideas? Thanks
big10p
Coins detected in pocket!
6,091CR
I'm struggling to work out what exactly this transformer is, tbh, as you also have a switcher in there. And I've never heard of an ISO transformer with a reset button. Sounds like it might be going into auto shutdown for some reason, though. What cab is it? As favouredson says, open it up and get some pics posted of what's inside the yellow metal case.
favouredson
Super Star
1,260CR
Retrojedi74 said:
Well I have checked the earth on the transformer and seems ok?......
Sorry, I meant the earth wire laying next to the transformer which connects to the switcher, the one with insulating tape wrapped around it...
Retrojedi74
86CR
Here is a picture of the box inside, after speaking to an electrician today about coming around he suggested speaking to a tv engineer about my problem. I call a local one up and explained what I tell ( which isn't much )?? Anyway he said when I moved the machine I could of disturbed the capacitors in the power supply and told me to leave it switched on for a couple of days to see if they will build up with power. If that doesn't work then he will come around and have a look on Friday. ??
big10p
6,091CR
Ah, a picture speaks a thousand words!
And yeah, the white one. It definitely should pull out. Without the back door on to hold the switch in, the cab shuts off, for safety reasons.
big10p2017-08-29 19:22:34
Retrojedi74
86CR
Hooray, you guys are spot on about the switch thank you. Now I've got my 512 in 1 game elf pcb running the picture is slighly moved to left of the screen.
so could I use the blue and brown controls on the monitor H & V ?
Sorry for the bright flash on the pic lol..
big10p
6,091CR
Don't touch those controls in the pic. The horizontal position control will probably be on the back of the chassis (the main monitor circuit board) but you may have a remote cable plugged in. Best thing is to take a pic of the chassis and someone will ID it and let you know how to adjust it.
big10p2017-08-29 20:23:55
big10p
6,091CR
The chassis is the brown circuit board you can see in that last pic, directly below where the red and blue knobs are. Take a pic showing the back of it, where all the cables plug into it.
gunblade
9,129CR
there will be a remote board in the coin door area I imagine as I can see a remote extender cable in the photo
you will be looking for horizontal amp for the size and horizontal shift for the position
it is a hantarex polo 1 monitor btw
