Restoring move function in Outrun
Hello everyone, this is my first post here and I am relatively new to the world of arcade cab ownership. To make a long story short I am a documentary filmmaker from Canada who is part of a small company that specializes in films on pop culture brands like He-Man, TMNT and so on. We are currently working on a film about a certain game and developer and bought an Outrun Standard Moving cab basically for a couple b-roll shots. This has turned into a pet project of mine trying to restore it just for fun.
It came with Outrun and Turbo boards, both of which were fried, no CRT and for all I knew wasn’t going to work at all. I found an awesome guy in the States who re-built the boards and i got a VGA computer monitor up and running and all was well until I blew the steering gear and now I’m waiting for those replacements to come in the mail.
As I expected the move function didn’t activate when I fired it up for the first time. For the shot in the film it would be really nice to make this work. So my question to all of you is, does anyone know anyone who has re-built one of these? I’d love to pick their brains to see if there are any obvious ways of attempting to restore movement even if it was temporarily or a way to fake it for camera.
Thaaaanks!
Flinnster
The Dino King
29 (100%)
2,566CR
We have folk on here who have recreated the drive PCB in it's entirety. However, you'll need to try and work out what exactly is at fault to make progress (it may well be the drive PCB however).
5,332CR
What's a standard moving cab? Do you mean the ride-in 'deluxe'?
If so, yeah, we made a run of motor drive PCBs and I could do more (I think we filled the gap in most folk's cabs and cupboards
But an Outrun Deluxe isn't going to move with a PC in it - you need the proper game PCB to handle the I/O to the motor drive PCB.
For just the FX, you could manually power the motor with some big switches and a beefy PSU that does up to 50V and maybe 20A, however you will royally f**k stuff up if you take things to the end-stops (as the proper circuit contains limit switches and other protection ).
Yes the one in the video is what I have. You’ll have to forgive me as I don’t know all the short forms and terms for the different components. As I understand it the board near the bottom of the cab at the back just beside the power supply is the one that drives the motion? If so how would I tell if this part was the problem vs anything mechanical, or otherwise underneath? Are there common issues to look for in these systems other than obvious things like fuses?
5,332CR
The motor drive PCB is like this (our repro): http://www.ukvac.com/forum/outrun-space-harrier-dlx-compatible-motor-pcbs_topic365882.html
This board will drive the motors and handle limit switches etc.
But... it's dumb. The brains are in the main outrun game PCB, and you were saying you don't have that - there's a PC in there instead.
If that's the case, then there won't be any signals going to the motor drive PCB and there's no viable way right now to get a PC running an emulator to interface to that motor drive board - you need the real deal.
5,332CR
Oh, wait a minute - sorry, I need my eyes tested - you have the actual outrun game PCB working in there ... that's sounding better
So is there a ribbon cable going from the main board to the motor drive PCB, and also are the transformers and all other wires present to the drive PCB? I presume it fails on boot with a motor fault?
edit: If you want the motor drive PCB checking-over (and maybe fixing), I'll do it for the cost of parts and postage if you don't mind posting it across the planet,
John Bennett2020-11-13 23:17:57
So the major problem is my cab is at our studio which is a half hour away and I’m not there often hahaha. So I can’t answer specific questions quickly. There is a ribbon cable I connected from the rebuilt PCB for the game to what I assume is the motor PCB. from there i don’t know as I wasn’t looking that closely at it when I first tested it. I’ll take some pictures to post next time I’m there in the next few days. How do I see what fault it’s reads when it boots? Is this in a test menu? Anything else I should take pictures of while I’m at it?
5,332CR
Gah, my problem is that I've never touched a real cab, I just made the PCBs for others (hopefully someone else can help with more detail).
But I don't think you'll get any sort of detailed error message - it's a one-way thing - the game either moves or it doesn't and it passes or fails. The game PCB can't know any details about why it's not moving as the motor drive circuit doesn't sent fault data.
So I guess just check you've got an error at start. If not, then I wonder if it's a settings/ROM issue (I must admit, I don't know what determines whether a game board is an upright or motion)
5,332CR
All the bits look present on that board anyway, so that's a good thing.
In the link I put above, there's a manual I wrote that has debug details, should you have access to an oscilloscope, or a friend with one. But check there's at least a error from the game board first.
Outrun2
Colonel Outrun
1,184CR
You might want to check the dipswitch setting on the game board as the cab won't move if it's not set to 'moving' type. Always worth checking the basics first, the game board may have come from an upright cab.
Dipswitch bank B:
1 and 2 should be in OFF position.
Sweet I’ll check that for sure! I can’t wait to crack this thing open and see if I can’t fix it. Is there any easy way into the underside or does one need to take apart everything on top? I can’t find any videos or step by step on taking the cab apart
So I popped into the studio today and had a quick look. So far as I can tell the dip switches are in fact in the wrong position. I would have never known to look there. However I did not change or test them yet as I don’t have a steering wheel attached, as I am waiting for the new replacement gears to arrive.
The thing is, I am wondering if I should get underneath and clean and grease before even trying to turn it on. But then again maybe that would be for nothing and I should test first.
Has anyone taken the seat and everything off one of these? How do I even go about getting to those mechanical parts?
ColinD
6 (86%)
1,367CR
My Cannonboard / Cannonball interface allows the PC to control the motion, but have the project on a side burner for the time being. Oops... as you are running the real board, yes, you need to set the dips as you have above and it should run a motion test when first powering up.ColinD2020-11-16 13:26:56
Amazing!! Thanks for the tip. As soon as I rebuild this steering column I’ll get it all back in and test it. Crossing fingers. Even if it does work I feel like I should still get under there and grease it again. This thing is pretty dirty.
ar2r
143CR
Jumpers are first thing to check, if they are setup correctly you should get a message saying something like "motor testing" when you start the cab, hard to miss,
If that's fine check the cables are connected properly, my monitor lost colours because of loose connection.
Check fuses
Another thing would be brushes in the motor itself, happened to someone i know,
Unfortunately mine stopped moving without a reason and same happened very recently to someone else I know. Coincidence but makes me wonder if something is breaking due to age, I already have ukvac repro board so I know its not that ...
5,332CR
I take it you tried an original as well as the repro? - I'd hate to think our repros were failing, but need to be sure!
Reminds me, I need to look at that audio amp board for you at some point - it's moved up the to-do pile a bit (sorry)
