I'm starting to learn to fix my own boards and I would like to buy a ROM burner/checker. Most of my boards are early 80s like missile command, pacman etc. Any recommendations on what I should buy, price etc?
Mike
Mike
wakko said:Maybe someone can confirm if they've successfully programmed older 2716's using the TLC866. I've not tried it myself but the devices are listed on the supported devices page.
I'll be very interested in the reply as I'm looking for a rom burner to.
http://www.autoelectric.cn/minipro/miniprosupportlist.txt
silverfox0786 said:I use a MiniPro as my general go to burner.
GQ4-X is also another general one but does not do 16 bit chips without an Adapter so i revert back to my MiniPro
and i use my very expensive Xeltek Superpro 610P for some of the obscure chips inc the 2716 which is does without issues every time and also has a insertion detection
one thing to bear in mind with the 2716 is that the 2816 is a EEProm Flash chip that is pin compatible with the 2716
wakko said:I'm afraid that eprom still burns at 25v. It is an issue with a few vintage roms. The TLC866 is still a powerful burner as well as a TTL tester so I'm sure you'll be finding uses for it.
Check out the GQ4X v4 programmer. That definitely can program at 25v.
