Rom Burner
petercasino
212CR
I'm starting to learn to fix my own boards and I would like to buy a ROM burner/checker. Most of my boards are early 80s like missile command, pacman etc. Any recommendations on what I should buy, price etc?
Mike
wakko
23CR
Try looking on the favourite auction site for 'TL866CS Programmer'. It has got good reviews, covers a lot of devices and is great value at only £27 !
penrhos
747CR
I've got a Dataman S4, GQ-4X and a TL866CS.
The TL866CS is great value for money and can program GALs too - it's the one I use most, mine came with some chip adapters & an extractor and cost about £35.
penrhos2016-07-07 13:26:44
Equites
Chief Sheesher®
35 (100%)
3,332CR
I use a Dataman 48XP for modern stuff, and a Data IO 29B for older stuff.
Most eprom burners are absolutely pants at burning 2716 eproms which are common in the golden age era.
My Dataman failed around 30 2716 eproms, it just would fail to burn them. So I put them into a 'Bad?' box.
The Data IO went through them all and only failed 3.
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
I use a MiniPro as my general go to burner.
GQ4-X is also another general one but does not do 16 bit chips without an Adapter so i revert back to my MiniPro
and i use my very expensive Xeltek Superpro 610P for some of the obscure chips inc the 2716 which is does without issues every time and also has a insertion detection
one thing to bear in mind with the 2716 is that the 2816 is a EEProm Flash chip that is pin compatible with the 2716
silverfox07862016-07-07 13:55:05
petercasino
212CR
Sounds like I need to buy a more expensive one for the older chips then. Do I need anything else, apart from blank chips and a pc? I noticed you can buy different adapters for some of them.
wakko
23CR
Maybe someone can confirm if they've successfully programmed older 2716's using the TLC866. I've not tried it myself but the devices are listed on the supported devices page.
I'll be very interested in the reply as I'm looking for a rom burner to.
http://www.autoelectric.cn/minipro/miniprosupportlist.txt
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
you cant do it
2716 requires 25V and the max the programmer can internally stepup is 21V (in fact the software has a max of 21V)
so although the minipro software can in theory do 2716 chips physically it cant due to VPP voltage being wrong and programming fails
petercasino
212CR
I've found a Superpro here:
http://www.ebay.co.uk/itm/Xeltek-USB-Superpro-610P-High-speed-Universal-Programmer-/172243279464?hash=item281a7fde68:g:eek:oAAAOSwQTVV~4Eo
Would I need to buy any adapters in addition to this or would it just work out of the box?
wakko
23CR
Wow, they missed a trick only supporting up to 21V Vpp and misleading that they list the 2716 as a supported device
Maybe the GQ-4X V4 is the one to go for then, still cheap at £80.
wakko
23CR
I've found that some 2716's such as Fairchild's NMC27C16BQE-200 have a Vpp of 12.75v so should be fine with the TLC866. Might be a pain digging them out though.
wakko
23CR
I'm afraid that eprom still burns at 25v. It is an issue with a few vintage roms. The TLC866 is still a powerful burner as well as a TTL tester so I'm sure you'll be finding uses for it.
Check out the GQ4X v4 programmer. That definitely can program at 25v.
funhouse
362CR
Cheers. Will get one of those too.
penrhos
747CR
If your set on getting a GQ-4X - wait until the 12th when Amazon have their offers on, I bought mine on Black Friday and got it for £60.
It can't do PAL's/GAL's and you need to buy the ADP-054 if you want to burn 27C1024/27C400 etc which TL866CS can burn out of the box.
Some of the old 25V eproms have modern variants that'll program at a lower voltage so you may not need to get one.
Also the GQ-4X need an external PSU to burn at the higher voltages - it fails to burn if you run it on USB.
RGP
Meeter & Greeter
2,039CR
I have a TL866 which will do 2764 and up and GALs.
A GQ-4X which does 2716, 2532, 2732 etc - I use this the most because of its adaptors and it can do 42pin 8mb chips.
I am trying to obtain a Dataman IO29B so I can do PROMs although i've been in discussion with a genius about the possibility of a modern PROM burner.
penrhos
747CR
I fancy a Dataman 48+ Pro but I can't justify the spend - I missed out on one a couple of weeks ago for just £350 and there was a Dataman S6 that I forgot to bid on that went for £350
back in April.
