screen conversion
si07
11CR
Hi folks
Is it possible to use a 26inch LDC tv ... replacement of the old screen in a daytona cab ? if so how easy is the swap and what do i need to connect all together ? thanks again
obcd
3,830CR
Daytona is a medium resolution game. This means the horizontal frequency is 28 khz instead of 15 khz. Other than that, newer LCD tv's usually are 9:5 or even 10:5 in size proportions while the older CRT's were 4:3. To have a correct (not stretched) image, you will need a letterbox mode on your TV showing 2 black regions left and right of the image. A 26 inch TV will have less height than the original tube so the picture will be smaller.
There do exist video converters that might convert the 28kHz video signal into a signal that the tv can use, but some decrease quality while others introduce a delay in their output. This makes playing the game more difficult as some milliseconds already passed before you see the turn upon which you need to turn your steering wheel.
Your tv might not power up and not select it's proper input after a power cycle. In such case, you'll need the remote to readjust the correct settings at every powerup.
Besides that, you will need to adjust the bezel as it's made for a curved tube, and the new lcd will be flat.
I am nevertheless curious as well to see if someone knows a good solution.
Some people use the pc model2 emulator instead of the original hardware. This approach can fix the video issues, but it's not easy to recreate the original steering feedback. I remember reading that the emulator also runs slightly faster than the original gameboard.
obcd
3,830CR
Yes, the new monitors are 9:5 or 10:5 as well, however,
some emulators have a wide screen implemented that didn't exist on the original hardware.
Make sure you choose the correct tft panel. Some have a real small viewing angle.
A pc screen also isn't having the powerup issues. Most remember their used input (or select it automatically) If you use original hardware, you will still need an upscaler to get the proper resolution for the screen. 28 inch are becoming affordable nowadays and hardly cost more than a TV of the same size. I have no experience with such conversions. I just want to point you to possible problems among the road.
