Scud racer force feedback error
Shinydaz
814CR
I brought this machine with an fault on the ffb but would be great to fix it. Still playable but more fun with ffb. Where do I start, common er20 faults?
Video
Mr20to5
1,366CR
From mine, which had the same fault, the manual is really sketchy on what this could be, although my board had some clear leakage/corrosion on it.
It was a simple new ffb bought and fitted and problem fixed. It's not a bad idea to try and build up some spare boards for the model 3's if you are thinking of keeping for a length of time or getting more.
Good luck.
bbz149
26 (100%)
1,608CR
I would 1st squirt some Switch cleaner into the Steering Pot! Had the same prob on one side of my Twin! Squirt some into the little hole in the Pot and move the Wheel L+R a few times
5,413CR
I think that was the error I had when i had no bracket or pot, I tried connecting a pot, turning it manually at test sequence but it still didn't work, once I'd made a bracket and fitted pot and setup in centre it worked fine and error went
I would start with pot, if you have a meter, test the pot too, check it's in centre too
Outrun2
Colonel Outrun
1,182CR
Your wheel moves to the left during initialisation - mine doesn't do this. Is the pot definitely centred? It should read 80H in the input test when centred..
Shinydaz
814CR
Centre of steer reads 10h (7fh)
Centre of cabinate reads 10h (80h)
I tested pots and across each end read 5.17 and goes from zero to 5.17 on each end terminal when positive lead in centre terminal. I'm a novice at this stuff I'm afraid. Appreciate your input everyone.
obcd
3,830CR
You "think" the pot was changed. The thing doesn't know what you think...
My point usually when people say "I think" it means "I have no idea...."
So yes, test the potmeter on the input test. On Daytona 1 Force Feedback pcb you had a 2 digit led display that shows the value of the potmeter in hex (between 00 and FF) No idea if it's still there on the scud race force feedback pcb. You might be able to have the reading in input test. Just don't confuse with the normal steering readout which uses another potmeter. Slowly turn the steering wheel left and afterwards right and see if the readout decreases and increases without sudden jumps that could indicate a bad spot on the potmeter. I even think
that the 2 potmeters (the one for the steering and the one from the force feedback) are identical and interchangable.
Shinydaz
814CR
Yes the readouts on the ffb board are in the video, they read 1818 on boot up, then flash er20, moving the wheel doesn't show any values as it just flashes er20.
obcd
3,830CR
The cabinet value is probably for a deluxe moving cabinet.
10H in center position is wrong. It should be between 7Ah and 86H
obcd
3,830CR
Between pin 1 and 3, you should measure 5V. Between pin 1 and 2 you should have approx. 2.5V in center position. Between pin 2 and 3, you should have 2.5V as well. If you move the wheel, one reading should increase and the other should decrease. Their sum should remain 5V
terminator2k2
327CR
I think you will find model 3 games only use 1 pot...
Shinydaz
814CR
Confirmed the pot had been changed by previous owner. Seems a bit weird how it goes to the left so much on start up like you say.
Fantazia2
2,246CR
It could possibly be that he has replaced it, but not centered it correctly after replacing.
obcd
3,830CR
With the steering wheel centered, mechanically disconnect the potmeter so that you can freely adjust it. Go into test screen and adjust the potmeter for a reading as close to 7F or 80 as possible. Remount the potmeter in that position.
obcd
3,830CR
Kind of strange the game is playable if the steering potmeter is totally misaligned. You would expect the car to go off track pretty much instantly.
