Scud racer force feedback error
Fantazia2
2,246CR
Cant you normally calibrate the steering in the game to match the pot range, I know that I tend to have to do it when I switch games in my none FFB driver.
So if the pot is shared between the game and the FFB, then the game could be calibrated to drive ok with a misaligned pot but the FFB would be expecting the pot to be mechanically centered, or set to a specific "central" setting.
Heres a link to manual incase you dont have one already
http://www.crownleisure.co.uk/Documents/Manuals/Sega/Scud%20Racer/Scud%20Twin.pdf
Fantazia22016-02-01 22:25:23
Outrun2
Colonel Outrun
1,184CR
Try the pot centring first then check connections from ffb board right back to dash - bad connection could give odd errors like this. Has it ever worked on this cab?
Failing that, maybe you have the wrong chip in your drive board? (Longshot but worth checking).
I might have a spare ffb board if you wanted to try one.
Shinydaz
814CR
It worked last year for the guy who I brought it off then just packed up on him.
Trying your board would eliminate that if it gives me the same error, I'd really appreciate that, thankyou.
bbz149
26 (100%)
1,608CR
They do just go! I have only changed one in the few years but the Wheel didnt move at all when mine went faulty. I keep a few spares for mine, F355 Servo board also works fine
bbz1492016-02-01 23:47:55
Selina
53CR
maybe nothing to do with it, but maybe worth a try! i always asked myself for what this micro-lil pots are at the ffb-pcb. maybe you never realized them, cause they are so small. what Function do they have!? i never would give them a try to see what changes!?Selina2016-02-02 07:09:44
Shinydaz
814CR
When the force feedback stopped working for the previous owner, it pulled to the left on startup just like the video, so he replaced the pot, I've checked it's centred. So I think we can rule out the pot is the issue.
Shinydaz
814CR
Outrun2 sold me a drive board and it fixed the problem, so big thanks to him.
It would be nice to find out what is exactly wrong with my old one, any obvious culprits on my boards anyone can suggest?
Outrun2
Colonel Outrun
1,184CR
Glad the board sorted the problem. Who knows why these things go down - if you're lucky it's the fuse but more often it's more serious. I've got a few dead ones here
Shinydaz
814CR
Fuse was good, will test some components out when I get time, bit of a novice at it,but will crack open my new multimeter and soldering iron and see what more damage I can do ;)
5,415CR
I was convinced mine was going to be dead, specially when I forgot the foot plate wasn't there and stood on it
but it still worked after hooking up a pot
that's bad luck but good you got one and it's working, can't be without the FFB
Mr20to5
1,366CR
Glad you got it working. Mine was dead too and a nice new replacement soon got it sorted. Can't be without FFB. I did play it without for a wee while, whilst I randomly tried to get the old board working (I didn't) and it is soooo loose without it.
