Sega Naomi jamma
Pharo
197CR
Well that was a struggle but got there in the end 🤣,had to take the monitor back off after thinking I had it perfect as the bezel wouldn't fit as the monitor was to far out so took the the metal spacer off the back so it sat on the frame and it looks fine now.
A couple of questions now hope I can explain it right, there is 3 earth cables if looking at the cab one on the right which I connected hopefully in the right place one on the left which is 300mm long and one coming off the control panel with a connector on it.
Also still can't find where to plug in the degause cable that comes from the monitor I think I'm having a blonde moment.
Still got the monitor back casing to hopefully the bolts I need get delivered today 😄
Pharo
197CR
Here's the pics I took hopefully explains it better.
Fantazia2
2,200CR
Does the bezel fit the monitor perfectly, there are 2 usual ones Sanwa and Nano and one is curvier than the other, and 2 sets of the metal spacer, but the other one is thicker, can remember which one was for which monitor.
Not 100% sure on earth cables, there is usually one that comes out of the base and bolts to one of the bolts attaching the legs, and the one that attaches the monitor frame to the bottom right mounting nut but that one is usually quite short. Photo below about the degauss button (Demag in picture) shows the control panel ground attaching to some other connector in the metal panel that likely ties it to ground on the metal panel.
The degauss cable I think you may be missing the loom that it would attach to as the degauss button is on the bottom part of that metal panel under the monitor controls, I think there is some pins coming our on the right side of it (Looking from the front) and that would attach to a loom that would part go to the original JVS I/O and have a connector for the degauss cable to plug in to., and also a connector to original sound card for volume adjustment.
Circled red in this picture.
xMasterPx
182CR
Yeah that’s the tricky part because cab is intended to be wired for JVS, so things won’t sync up well converting it to Jamma not without doing some adjustments.
I guess push button could added to degauss cable to replicate the function.
xMasterPx
182CR
That Earth connector on the control panel would go into female 2-way AMP UP that’s mounted on that metal panel with the service & test buttons.
Female 2-way AMP UP would have two Earth wires coming out back to be connected somewhere on the cab (guessing it would be on the legs)
Fantazia2
2,200CR
It goes to the metal panel itself under the control panel, and another cable comes up the left leg (or is bolted inside the left leg near the control panel) to bolt to the metal panel to continue the earth path.
Pharo
197CR
Here's what I did with the 2 earth wires I hope it's right,just need to find out where the one from the control panel with the connector on it goes to.
Fantazia2
2,200CR
The control panel you wont be able to do anything about as the connectors/loom is missing from the metal bracket.
I wouldnt worry about it too much it wont effect operation, its more a safety thing in a public space in case mains voltage somehow ended up getting shorted to the metal control panel.
Pharo
197CR
Cheers that's what I was hoping for,I soldered the cut wires and fed them back up the legs so all I need to do now I think is get a decent jamma/cga-vga converter as I've been told the one in the cab is rubbish and get a better psu as I've been told that is also crap,then I will have to do a bit of reading to see how to wire up a new jamma loom 🤣
Ace`
PlanB contributor #1
38 (100%)
3,820CR
I've got an original Sun power supply that's been recapped for sale if you're looking for an original rather than a switcher. As for the vga converter this is probably the best one but it's out of stock at the moment.
Pharo
197CR
Cheers I did look at the irken labs one shame it's out of stock,the sun psu would be wasted in this cab as it doesn't have any of the original wiring it's all been ripped out and converted to jamma.
Thanks for the offer.
Cheers Brian
Pharo
197CR
I just noticed a small button on the underside of the cp would this be used for crediting a game.
Pharo
197CR
Well that's the cab put all back together bar the sides so thanks to everyone who helped me with this just need to get a jamma loom and a better cga-vga converter then I'll be ready to ask more questions 🤣
Thanks again Brian
xMasterPx
182CR
Thanks again Brian
Glad to see it coming together!. Keep us posted on its development 😀
Question are you going to remove all the current CP wiring in place and wire the Jamma loom directly to CP buttons/sticks?
