update....
so ive now got sound on machine, turns out the volume control in coin box needs to be turned up to maximum...doh...double doh!
also fitted a working motor for ffb...and guess what...no ffb. although when i turn the machine on after fitting motor the steering test menu came up for the first time..but no ffb...i did memory test and got bad ic30, ic34, ic38, ic19, ic2, ic6, ic10, ic18, ic28, ic32, ic36, ic40, ic17,
a bit strange because all memory has been good before?
now the game goes straight to er20 or er02 and also on screen says malloc failed in dup ram.
this is only on unit one, unit two is off at the mo so i can concentrate on unit one,
bearing in mind I've change motor drive bd and drive bd and game bds what's peoples suggestions ?
thanks
