sega rally 2 issues
Sbdesign
SEGA collector
1,726CR
Digital Sound Board version 2
Music comes from this not the main stack, but if missing / broke / unplugged - you still get menu noises and engine sounds, so I don't think its this.
Its in front of main stack to the right I believe, and its another metal box with the board in it.
smc
4CR
thanks sbdesign, no that's all working fine I'm gonna hook up a external speaker to channel 7-8 on face board to games stacks see if that gives me anything.
smc
4CR
update...traformers are fine...have checked a lot of things today and its driving me mad... still getting error 20 on drive bd and still no sound at all from music bd and car noise from sound bd, and still no ffb, so far up to date i have changed motor drive bd, drive bd, mpeg music bd, game stack all bds, checked connections belled out wiring looms,,,
when i got the game it wouldn't even boot up, so fitted new ( working second hand) game stack (all bds) and game booted up and started to play,,, with no sound or ffb, could it be something on sound bd? maybe take old sound bd and put it in new stack?
I'm scratching my head!!
Sbdesign
SEGA collector
1,726CR
ERROR 20
ARCADE CONTROLS FORUM - SIMILAR ISSUE
Someone suggested he unplugged everything and re-attached and the ER20 went away.
It could be the game board, but still things to try.
I had trouble on the DX cab and FFB. And its horrible spending a evening trying everything and gaining nothing for your time. BUT We all seem to get there in the end if thats any consolation.
Does the game play ok? Is the steering centred at 80H in the input menu?
Does the car handle ok? so the game plays?
Are you still getting no movement on the wheel ever? no movement on start up?
On failed DR BD's I was getting steering going left on boot but not moving right to complete calibration, but just staying there. New FFB bd (with digit display) fixed it.
It could be the steering control panel at fault. Im not confident that this is your issue as I have never had a issue with the motors, but others with greater time in this field may have different and more knowledgable experience.
Sbdesign2019-04-28 09:38:31
smc
4CR
thanks for your info, yeh the games play fine and the car handles fine I'm getting no ffb on start up calibration and game play, steering is at 80h in menu, ive replaced drive bd and motor drive bd but still same problem, think i will disconnect everything and check all plugs including games bds, I'm confidentt its something simple same with the sound ive got no music or game play sound at all but ive checked all bds for this and speakers are humming which suggests amps are fine, when i got the game i hade to give it a good clean which involved unplugging a lot of stuff I'm wonder5ing if ive somehow got something plugged in wrong because i have identical problems on both units!!
on wards and upwards!
an im gonna watch the f1 gp now to have a rest from arcade repair!
thanks agin i will let everyone know i next update.
smc
4CR
hmm I'm starting to think that if ive got a broken motor on my steering mechanism that could be causing my error 20 ?
ive changed all relevant bds but still no joy to my ffb problem,, has anyone heard of a broken motor causing a er20 fault?
still no idea what the problem is with the sound yet, I don't think a broken motor would take the sound out aswell ??
Sbdesign
SEGA collector
1,726CR
no it won't effect sound.
Won't be harmful to whip dash out, just to see whats going on back there.
Is the motor there? are the belts on it? - most likely yes / yes but if not that could cause it
Volts at motor check
smc
4CR
had dash out today but my volt meter is now broke thanks to my kids!
belt was attached, I'm getting power to motor drive bd, will volt test motor when the shops open tomorrow
obcd
3,830CR
One broken motor is possible, but how big are the odds to have 2 broken ones. Besides that, the error is different on both FFB boards. The only thing I could find about ER02 was an issue with the FFB board rom.
Consider your problem as being 4 different issues. The sound issue could be the same on left and right cabinet, but don't assume it is. The FFB issue has a different error code on both boards, so likely is different on both sides as well.
I wouldn't be suprised if operators don't care about force feedback and will leave the machine working without it when it fails. The FFB rom is likely in a socket, so you could exchange it between boards to see if one of them isn't bad. Don't try to fix all issues simultanously. Focus on one and try to elimenate possible causes. Find the sound output on the game stack filter board and connect some amplified pc speakers or even a stereo set to it to see if it produces any sound. If that works, check the signal further till the input of the amplifier board. If you still have sound there, it's either the amplifier board or it's supply at fault. The volume controls can be defective or miswired as well.
Music comes from a separate board and cage. Again, what are the odds that game sound and music sound are both defective simultanously? The board combining the audio signals just contains a couple of resistors if I remember well? If that's the case, not much can go wrong there.
Sbdesign
SEGA collector
1,726CR
Good advice, I agree regarding all the simultaneous issues.
OP: its hard to keep track of what is tested and what is what, perhaps update main post with a break down of things checked and whats happening, every time you post an update then update the first post.
I have missed some details such as 2 drive boards with 2 different issues.
Driveboard swap:
Am I right in thinking you have tested 3 838-12898 Board? 1 from each twin, and 1 new one?
Both originals Started on ER 20 on each side?
obcd mention Er02 but I haven't come across that in your post, is this on the new board?
with the new one, did you check all dips are the same also?
smc
4CR
Thanks ob and adpolice, yes when I originally got the game player 1 had er02 so I change drive bd still the game wouldn’t boot up so changed the game stack and the machine booted up and I can play games but without any sound or ffb (new game stack and drive bd came out of working machine)
Player 2 on purchase had glitch on screen and 02 - - on drive bd, I’ve changed motor bd and drive bd with no effect, it plays with no sound or ffb,
I will concentrate on player one and check ffb bd and update this thread. Thanks guys
smc
4CR
update....
so ive now got sound on machine, turns out the volume control in coin box needs to be turned up to maximum...doh...double doh!
also fitted a working motor for ffb...and guess what...no ffb. although when i turn the machine on after fitting motor the steering test menu came up for the first time..but no ffb...i did memory test and got bad ic30, ic34, ic38, ic19, ic2, ic6, ic10, ic18, ic28, ic32, ic36, ic40, ic17,
a bit strange because all memory has been good before?
now the game goes straight to er20 or er02 and also on screen says malloc failed in dup ram.
this is only on unit one, unit two is off at the mo so i can concentrate on unit one,
bearing in mind I've change motor drive bd and drive bd and game bds what's peoples suggestions ?
thanks
obcd
3,830CR
Have you measured if you have 100V AC on CN5 of the motor drive board?
On CN5 of the drive board, you should measure a 0V - 5V on pin 5 and 6. That voltage should increase / decrease depending upon the position of the steering wheel. It's worth a check if it's present.
Are you sure the original boards and your replacement ones are having the same number. Does the eprom have the same type number?
CN2 connector on the motor board has 2 alarm signals and an alarm reset signal. What voltage do you measure on those lines?
This are just a few randow things you can test if you haven't done so already.
Outrun2
Colonel Outrun
1,184CR
Hard to keep track of what the latest state of play is here.. the game stack was running fine but since you replaced the motor it's showing a lot of errors? Does the game run fine like it did previously?
Very unlikely to be a bad motor, these motors are industrial strength and almost never fail. I've had loads of Model 3 dashes and the motors always work.. even when covered in rust!
Pretty sure the ffb test will run when the cab is switched on, regardless if there is a game board fitted. It's usually done before the monitor has had chance to warm up and display a picture on Model 3 games.
My guess is bad connection between dash and drive board/motor board.. some of the signal wires going to the AMP-UP motor plug are tiny and can be pulled out very easily! If even one of them is loose you'll get drive board errors.
As for the sound, volume control is an obvious check, did you not try this at first or did you only try after checking connections? If you have the pots up to the max there is an issue, because put it this way, if you have the volume up to max you'll know about it and so will your neighbours!
There is a volume level control in the game settings.. maybe these are low?
smc
4CR
thanks outrun2 for your input, im not sure how change title of topic to something new like update so fare.
anyhoo so sound works fine now i had to turn volume up to max for it to work and then turn it down in game menu,
thanks for the input about ffb operates regardless of game bds i wasn't sure if there was a link there,
i have belled out all wiring from motor to motor drive bd and all was good, im getting 100v on power into motor drive bd, one thing like i mentioned was when i fitted new motor in dash and turned on it allowed me to do a steering test for the first time!
but hasn't repeated it since, just says connection failed, but i think your right its worth investigating more.. the loom and plugs.
thanks
