sega scud ffb problem
Mr20to5
1,366CR
Hi guys.
Still the noob when it comes to this lark and looking for someone to spoon feed me please.
My first cab is a lovely Sega Scud Race sit down, which plays well with no graphics faults. However the ffb which was nice and strong has just completely stopped working.
I get a drive board error message on start up on the screen. The rest of the game is unaffected. I gave read a few threads about error messages on the board, snapped belts, etc, but I have no idea as to how to get to these or how to check them to trouble shoot.
So here I am seeking an absolute beginner's guide to help me out. Please note that I have never taken anything electrical to pieces. Scary stuff. So other than unplugging it first, I am at a loss, any even mildly technical terminology is also likely to go over my head. But I'm here to learn.
Many thanks in advance.
Neil
Oh, the rest of the game plays just fine.
Vamino
Insert coin(s)
2,698CR
Hi,
You say it was working fine before it stopped? Did it happen when you powered it up or did it happen whilst you was playing it?
I don't know what it is with the FFB on these Sega machines, but the FFB control board is known to fail.
Whether it's too much voltage or general wear and tear that causes it is anyones guess.
Does the board show any error codes?
The drive board lives under the footplate and has 2 sets of numerical leds, tilt the seat back and then remove the footplate and it should be lit up.
I've had them completely dead, and I've had them show an error code but still be faulty. I've also had an error code when I forgot to plug in the motor power connector.
Anyway, before you dig any further into electrics an stuff the first thing to do is to see if there are any leds lit on the control board.
Cheers.
Vamino2014-07-08 23:51:22
Mr20to5
1,366CR
Thanks Vamino.
It happened when I powered it up. So working fine when last played and turned off.
Spot on instructions for me which I will endeavour to complete over the next couple of days and post my findings.
Thanks again.
Neil
Mr20to5
1,366CR
Hey, you sound just like the IT dept at work.
Funny thing is it normally works.
I will try this first. A firm advocacy to the free and easy method.
Do you mean unplugging all the connections from the actual drive board itself? Only that board? Or all the boards and everything else I can find?
Thanks again
Neilneil16372014-07-09 10:46:02
ZedEx48K
8-Bit
1,423CR
I would start with the board, but the other ends of the cable prob wouldn't go amiss either to make sure it's a good conection all the way through. This has been mentioned before as a solution for another driving cab part that ended up as the fix.
Vamino
Insert coin(s)
2,698CR
When powering up, does the steering wheel move at all upon bootup?
But yeah, I'd definitely follow ZedEx48K advice, start at the control board first.
Hopefully it's something as easy as reseating a cable/rom on the control board.
bbz149
26 (100%)
1,608CR
Don't be surprised if its the Servo board like I said over on J+
Mines been changed before I got the machine and I did one side again last Year. Not seen a Control board go yet though! and if it is then I have a spare if needed
Mr20to5
1,366CR
Vamino, when it worked, then yes the wheel would move left and right as it calibrated itself upon boot up.
But it no longer does this either.
Not sure when I'll get chance to have a look at this but ill post up photos of whatever I find. I'll keep my fingers crossed until then.
Thanks for your replies so far. Knew I could count on everyone.
Neil
Vamino
Insert coin(s)
2,698CR
Sorry to derail the thread a bit.
What symptoms did you have when the servo board went mate? Did it happen when powering up or during gameplay? Luckily I've not had a faulty servo board yet, just control boards which have been blown/giving random errors. I did clean everything inside and out/checked voltages when first renovating the cabs and I've not had anything go on me yet (touches wood)......And yeah, I've got spares too just in case, the hoarder that I am.
Neil, your in good hands on here mate.
The guys on here have helped me out loads getting my cabs up and running. I've bought a few cabs now and if it wasn't for forums like this all I'd have is a mostly load of scrap instead of Sega goodness.
Mr20to5
1,366CR
Hi guys. Apologies for the delay. Never seemed able to grab ten minutes last week.
So, on tipping the seat back, here's what lies beneath and the lights I found....
This board as you all will know is directly under the seat. It has led1 on its own and this was lit up constantly red. Then on the opposite side of the board was a strip of 4 green led's numbered 2,3,4&5.
On power up 2 was illuminated but as the game played through each led lit up in turn.
I couldn't see any other led's on the other boards
This is the one on the right under the foot plate
And these are the ones on the left
So back to the experts for what I should do try first.
I haven't played with any wires or connections as the sheer number scared the crap out of me!
Thanks in advance.
Neil
bbz149
26 (100%)
1,608CR
If I rem correctly the FF just went and the wheel had no FF at all. I think the control board had something like FF err but cant rem. Last problem I had was the wheel would turn one way and throw up an error. I just needed some switch cleaner in the steering pot
Mr20to5
1,366CR
Bbz149 you remember correctly. One day the ffb worked fine, next day nothing except a message on the start up screen that said drive board error.
So I will remove the foot plate next but then what am I looking for?
Thanks again.
Mr20to5
1,366CR
Good morning gents.
Ok, so foot plate removed and photos below.
At an aside, how much dust! I felt like putting the Dyson inside. There was one loose connector on the back left board but nothing hugely obvious. Can't see any led's but most likely not looking in right place.
Please help. Again. On a plus, whilst checking to see if loose wire had helped I set my best ever time.
Mr20to5
1,366CR
Next question if I may.
Will any of these boards, wires, gubbins hold any electrical current when the unit is switched off.
Scared sh*tless about this electricity carry on.
Neil
VaNDAL_UK
46CR
Hi,
This part I highlighted looks like corrosion. I'd get a toothbrush and isoprop on it.
OR...
get the board under hot water and fairy liquid with said toothbrush.
OR...
Bung it in the dishwasher.
I bet that's the issue something has eaten at the traces.
VaNDAL_UK2014-07-16 16:54:03
bbz149
26 (100%)
1,608CR
Fairy Liquid has Salt in it apparently and if your sticking it in the Dishwasher be sure not to use detergent and not on a Heat cycle as I accidentally did with a Chassis
Mr20to5
1,366CR
Guys come on, get outta here. I'm new, ok, I admit this, but "IN THE DISHWASHER" come on..........
I though some very gentle rubbing with a cotton bud dampened with IPA at the most. But you are right there is some crusty white stuff on the board that doesn't look too healthy.
Even then I have no idea about electricity. So apologies for all the questions but with the unit unplugged can I still get shocked from removing these boards, wires, etc? Or certain parts like the capacitors, etc?
I read some shocking stories about monitors!
Please help.
Neil.
