tonyg64 said:
One thing though, would these blown caps stop the game from booting at all?
It could do if it had affected other parts of that board
If you look at the schematic for the board in the link below you can see that the amplifier (second page, right hand side) feeds in ground on (7) and (8) [these are the top connectors on the board if you look at the little diagram]
And sends out +18V on (10) and Speaker on (11)
The game also relies on a "Power on reset" circuit [above the amplifier circuit] which resets the CPU on boot, to enable the game to start
This runs on connector (9) so is very close to the amplifier circuit, and if there is no POR (Power on Reset) then the game will never start
I had similar with a test rig I setup as per second link below, and you can ground the board pins to simulate a reset
That's probably not that hard to test, but does involve getting wires out and doing a bit of testing
http://www.robotron-2084.co.uk/manuals/invaders/taito_space_invader_l_shaped_board_schematics.pdf
Simon Cromwell's reply about the Power on Reset circuit and what it does
http://www.ukvac.com/forum/does-space-invaders-midway-need-5v_topic346601.html
"The answer to this conundrum is simple: watchdog.
The POR circuit sits on the PSU and provides the pulse to the RESET pin on the 8080 to get everything going. (It's just a simple 555 timer implementation). For early boards, including some Space Invaders, then you'll need this circuit (or pulse the 8080's RESET pin manually) to get everything going.
But later Midway/Taito 8080 boards also have a watchdog circuit. This will also pulse the RESET pin if the 8080 isn't active. This is why the board in the YouTube video boots after a short pause; it's not being started by a Power On Reset circuit, it's being started by the watchdog.
This is why your later Deluxe Boards work whilst the earlier Space Invaders don't. The Deluxe board is being reset by the watchdog circuitry.
And it also explains the apparent contradiction on pinrepair.com: The "reset delay" is built into later board sets, but it's actually the watchdog circuit, not a POR circuit.
I had an Ozma Wars board-set which would not boot in the test rig unless the RESET pin was manually probed. Turned out one of the counter chips in the watchdog circuit was bad; after replacing that, the board booted happily (after a short delay) in the test rig. If your Space Invaders board set has the watchdog circuitry, then it's worth checking out"
