SPACE INVADERS HELP PLEASE (Progress made)
4,058CR
Tony - Neil (Arcader) is based in Cumbria, up near lake Windermere, or he used to be - I assume he still is. Where are you based? Your profile just says "UK" but obviously the UK is a big place. Always best to be a bit more specific (no need to give out your address, of course!)
tonyg64
22CR
Guddler, thanks. Im near Kenilworth/Leamington.
Tony
tonyg64
22CR
Thanks a lot for that Judder, I'm a bit scared of all that tbh but it makes good reading. Ill get a better look at the board itself later in the week and see if I can make sense of it more. If I can i/d the caps I may get them changed anyway if I can.
Tony
Judder said:
tonyg64 said:
One thing though, would these blown caps stop the game from booting at all?
It could do if it had affected other parts of that board
If you look at the schematic for the board in the link below you can see that the amplifier (second page, right hand side) feeds in ground on (7) and (8) [these are the top connectors on the board if you look at the little diagram]
And sends out +18V on (10) and Speaker on (11)
The game also relies on a "Power on reset" circuit [above the amplifier circuit] which resets the CPU on boot, to enable the game to start
This runs on connector (9) so is very close to the amplifier circuit, and if there is no POR (Power on Reset) then the game will never start
I had similar with a test rig I setup as per second link below, and you can ground the board pins to simulate a reset
That's probably not that hard to test, but does involve getting wires out and doing a bit of testing
http://www.robotron-2084.co.uk/manuals/invaders/taito_space_invader_l_shaped_board_schematics.pdf
Simon Cromwell's reply about the Power on Reset circuit and what it does
http://www.ukvac.com/forum/does-space-invaders-midway-need-5v_topic346601.html
"The answer to this conundrum is simple: watchdog.
The POR circuit sits on the PSU and provides the pulse to the RESET pin on the 8080 to get everything going. (It's just a simple 555 timer implementation). For early boards, including some Space Invaders, then you'll need this circuit (or pulse the 8080's RESET pin manually) to get everything going.
But later Midway/Taito 8080 boards also have a watchdog circuit. This will also pulse the RESET pin if the 8080 isn't active. This is why the board in the YouTube video boots after a short pause; it's not being started by a Power On Reset circuit, it's being started by the watchdog.
This is why your later Deluxe Boards work whilst the earlier Space Invaders don't. The Deluxe board is being reset by the watchdog circuitry.
And it also explains the apparent contradiction on pinrepair.com: The "reset delay" is built into later board sets, but it's actually the watchdog circuit, not a POR circuit.
I had an Ozma Wars board-set which would not boot in the test rig unless the RESET pin was manually probed. Turned out one of the counter chips in the watchdog circuit was bad; after replacing that, the board booted happily (after a short delay) in the test rig. If your Space Invaders board set has the watchdog circuitry, then it's worth checking out"
4,058CR
Could I suggest that you see if anyone local to you that knows their way around a Space Invaders would be willing to pay you a visit and do some basic diagnosis in exchange for a couple of coffee's and a chat?
I'm way too far away and I have to admit that Space Invaders is pretty much the one game from the early years that I don't get on with (electronically). Never really known why.
tonyg64
22CR
Yes good idea. If anyone reading this could come to CV8 area for a look I'd be very grateful. If no response on this thread I'll start a new one asking for help. Thanks
Tony
Battlezone
410CR
Ah I see there's another thread on these pesky caps (and some
good messages from Judder and others on the subject).
Tony,
It clearly looks like the caps are in the audio amp section.
Unfortunately none of the caps are identified individually on the
what I assume is a new schematic, but by checking direct connections
back from the edge connector with a multimeter you should be
able to figure out which cap is which. Based on the schematic they
all appear to be 10uF or 1uF (for the polarity sensitive caps), not
the 22uF or 15uF we were discussing in the other thread.
e.g I'd start by trying to find the 10uF cap between 10/L and ground
(there is only one cap directly connected to the +18V supply
and pin 14 of chip 22 (one of the amps with the heat sinks).
Then progress to identify the others.
One thing to watch for is that the blown caps might only be a symptom of the
problem rather than the problem itself (like I had on my Tron recently).
Maybe you can probe the +18V supply to check it's in spec.
Battlezone2016-11-24 18:24:40
tonyg64
22CR
Thanks John tbh I dont know where to start checking the 18v supply. I see it in the diagram but it appears from "space" :). Until I saw that i thought there was only 12v and 5 v and the unexplained -5v (which doesnt compute to me lol)
Tony
tonyg64
22CR
Thanks to Battlezone, I now have a basic understanding of the drawings and components. With his email tutorial I have since done the following:
Replaced the 2 caps shown in the pics earlier- this resulted in a screen I could recognise with a little confused (like me lol)
I then started checking voltages at the sound/daughter board and found there was no -5v.
I looked at the power supply board and found the -5v which is fed from the -12v and regulated down to -5v was not right so I changed the -5v regulator (5905 from memory) and the game powered up and works!
. Happy day for me. I couldnt have got this far without other members on this thread but especially Battlezone who is a very patient man and has inspired me to keep moving, checking things.
HOWEVER, during gameplay I have noticed a difference. At first the No of bases was 5 on start up as per my other thread about dip settings. I have switched them about to get 3 bases and one extra at 1500 pts, but even with the boards removed I was VERY careful with them and cant see that I'd moved the switches from previous settings.
The other thing is when I use the 22 and 14 counting method the first ship always came from left to right so after picking off the left hand 4 columns I would go to the far right (invaders still on the left at this point) and wait for it. But it appeared from the right and I missed it of course. After the next 14 shots it came out from the left and again I was having to run to the right to get it.
The 3rd ship also comes from left to right and is back on track in my opinion.
Can a voltage change cause the game to play differently and put the ships out in opposite sides?
BTW using the 22 and 14 shots still gives 300 score when hitting the ship so that still works as it should.
Tony
tonyg64
22CR
virtvic said:
Isn't it a great feelinig when you fix something yourself, even with help from others?
Sounds like you are a pro player, too.
Absolutely great feeling even with help as you say. Its been "off the road" for nearly a year so when it looked like it was working I left it powered up for an hour to see if anything blew and then played it for about 2 hours lol. Still a demanding game to play I reckon. Nowhere near a pro player lol. 13k is my highest ever but more like 8k is normal
. Just need to fix a volume pot for fire sound and see if I can influence the random gameplay re the space ships :)
Tony
