Substitute boxes
Purity
The Oracle
2,999CR
Pardon my ignorance but a friend introduced me to substitute boxes for testing various components today. I didn't even know these existed, but what a great idea, for testing capacitors etc
It made me wonder if anyone use anything similar for testing arcade parts?
5,653CR
Pix?
Purity
The Oracle
2,999CR
This is a capacitor resistor substitution box. So it ranges between different resistor and capacitor values.
Nothing exciting to look at, but an interesting idea.
Muppz
362CR
crickey, not seen one of those since God was a lad.
last time I saw one of those was when I was still training in the 80's and only then because we were throwing them out!
P-Man
International man of mystery
1,273CR
I dont know how you would 'test' a component using a substitution box...
They're ok for maybe teaching in a class, but there's no precision to them with the croc clip leads, the capacitance and resistance would be fairly changeable. ok for making your own circuits to light up lamps with a 9v battery, but not sure you can do much else with them :)
i'd say move on...
forcefulfil
EDOT King
1,675CR
maplin do a lot of gear for testing caps/transistors
but my multi meter does most too and monitors/power supply i usually re-cap anyway while im rebuilding it
forcefulfil2013-02-13 17:06:58
Muppz
362CR
We used them more for investigating faults than fault finding. when we were being taught basic tranny 1,2 & 3 stage amps we used one briefly in one lesson to observe differences in the waveforms caused by different R & C values by tagging these into circuit.
I can't see how they would be used for fault finding either unfortunately
Purity
The Oracle
2,999CR
Sorry I probably wasn't very clear in my original post. I didn't mean for fault finding as such, I meant more as a way of temporarily substituting capacitors or other parts etc that you suspect are faulty, so you can re-test with a known working part, and as a check that you are on the right track to fixing the problem
So, as Pman pointed out, "test" is probably not the right word that I used
Purity2013-02-14 13:23:53
