Sync issue
scubawaz
37CR
https://youtu.be/xGWt3eilKdQ
Please watch this minute video and see if you can help with my sync issue.
Many thanks,
Warren
Flinnster
The Dino King
29 (100%)
2,566CR
OK I presume you have other boards that display OK? Have you tried altering your monitor adjustments / pots?
Is this street fighter 2 board a bootleg? I couldn't tell from the brief look at it.
Sometimes bootlegs have wildly different video output signals to other boards. I have some that require a ton of tweaking of the vertical + horizontal syncs and positioning / sizing of the monitor pots.
Now every game will be a little different for sure, but I've found bootlegs to be the worst culprits for this.
edit: ok, finally saw the last half of the vid. sounds like you've tried the pots and combining h+v sync wires on the monitor then. Hmm any other monitor available to make sure the board is actually OK?
Flinnster2017-09-06 19:10:30
scubawaz
37CR
Yeah tryed adjusting all the pots but cant get it any better
I have a 30 in 1 and its the same, I think my SF2 is original crapcom.
Im thinking it's something to do with only having a vertical sync wire but no horizontal sync wire but real can't get my head round scyn issues and why some times you combine the wires.
My SF2 and 30 in one works fine on my 26 inch monitors but not on this hanty 20 inch. Any other idea?
scubawaz
37CR
Got it sorted buddy thanks for your help.
There was a switch on the hanty mtc9000 board ST4 on the schematics which I flicked to the up position it start to scroll and with a little vert scyn adjustment it's sound now.
Thanks for your help.
Flinnster
The Dino King
29 (100%)
2,566CR
Ah so that's cool, that eradicates the possibility of it being the boards at fault.
So it's probably something to do with the way the monitor is dealing with the combined sync I'd say. (Which is of course totally standard to how jamma works - there's only a single sync line).
Maybe the hanty chassis has a dip switch or similar to say use combined sync on a single input, or using separate H+V on two inputs. If there was a setting like that, it would explain why simply munging the wires together wouldn't help?
You'd need a hanty owner to confirm that one... none of my cabs have 'em.
Flinnster
The Dino King
29 (100%)
2,566CR
LOL ninja'd!
Glad you got it sorted
