Tech help: Bubble Bobble PCB
favouredson
Super Star
1,260CR
Are you sure about the PC030CM needing -5V?
I can't see it on my schematics and I get no continuity on my board either.
I get continuity with GND, +5V and +12V but nothing on -5V.
trm
2,877CR
Sorry about that - I'm having the worst most super-disastrous day so wasn't able to refer to the docs and was just going from what I recalled (I recognise the irony in this as I was so hard-core about stamping out edumacated guesses in another Tech forum).
As soon as I get some time I'll have a squiz at the BB schems and see what's what.
trm
2,877CR
So what's the current status of this? Is there a good image but no sound or is the image still iffy? Just catching up with all the current fixes :)
gridrunner
Ex-lurker!
206CR
Hello chaps,
Well I've got the amp chip I need to replace the TL074 IC on the board. I'm going to swap this out at the weekend and try again. Graphically and play wise the board is A-OK. However the only sound I'm getting is the scratching of the volume pot as I move it around and the initial pop when I power the game on. I'm hoping this indicates the damage is limited to just the audio section.
Stu
gridrunner
Ex-lurker!
206CR
Hello chaps,
quick update. Replaced the Op Amp and the problem remains. Can hear scratching from the volume pot but no sound. I'm going to check my PSU again and also check what current it can supply. Apparently some related problems are found on Rainbow Islands boards from insufficient current on the -5V rail. The manual suggests -5V @ 1 amp. The fuzziness on the screen was happening because of the -5V short. It's absent now.
I'd appreciate any more suggestions on what else to look at. All other game functions are fine.
stu
gridrunner2011-03-21 19:18:49
gridrunner
Ex-lurker!
206CR
Hi Guys,
I checked the power to the board today, something I should have really done much earlier. Anyhow all the voltages check out OK, and I decided to check the current value as my meter has this function. I tested this at the board edge connector:
+5V @ 200mA
+12V @ 1A
-5V zero
Now I'm assuming it isn't usual for the -5V rail to be drawing no current at all. I'm assuming this is because the board continuity is 'open' somewhere so there is no draw, or could it be a PSU issue?
I do have a spare Jamma PSU I can try. Not sure what I'm looking at here so guidance would be appreciated.
trm
2,877CR
I thought I'd posted last night about the -5VDC@1A but it looks like I forgot to press submit :) First, I can't see any way that board needs an 5 Watts of power on the -5V rail.
Secondly, I think you've hit the nail on the head with the -5V rail having no current flow being not good.
To test the -5V you have a couple of choices:
1. This should work on any style PSU. Connect a bulb - coin door, fruit machine etc - between -5 and GND and see if it illuminates.
2. This may not work on all PSUs as I understand some won't put out any power until a load is applied. Disconnect the edge connector and meter between the -5V pin and GND and see what you get.
From your comment about "the voltages check out ok" I'm wondering if you've already metered -5 and found the proper voltage (or thereabouts, the +5 rail is the one which you can adjust and the +12 and -5 are normally derived from the +5 so may be off slightly, which isn't normally an issue)?
If you have got -5 coming out of the PSU then I'd say you've got an open circuit somewhere. You could try taking a resistance check between -5V and GND on the game PCB. I'd guesstimate at something in the couple of hundred Ohms range, but if you find you get kilo or megaOhms or worse then something has gone OC.
Post back and I will definitely (and I mean it this time, work has been like a lunatic asylum) find some pointers to check on the schems.
gridrunner
Ex-lurker!
206CR
Hi Guys,
The PSU is supplying -5V and so I don't think it's the culprit. I think something else has gone open circuit on the -5V rail after the short. I just need to locate it and fix it, hoping it's nothing too expensive or hard to find!
Any pointers for likely culprits would be appreciated.
One other interesting observation: If I remove -5V the screen goes funny - it looks ghosted out. Is there a video component that also uses the rail?
ta
stu
andyman
1,059CR
Video dacs use -5v (see further up in YOUR thread
) hence the image failure, wont be anything to do with the sound though.
Andy.
Flinnster
The Dino King
29 (100%)
2,566CR
Epic thread resurrection!
Thanks to everyone above for pointing me towards Bubble Bobble needing -5v to be live.
I tried a new bootleg board pickup today and all was fine, other than getting noise/hiss on the volume pot and tinny background music somewhere in the distance.
After reading the thread I simply connected unused -5v connector to the switcher and job done.
Very happy!
Now I just need to find someone who can burn me the redux romset and I'm in Bubblin' heaven!
