bonehead said:
Just checked the pcb and it's the Y size pot that has a broken leg which is the left hand pot nearest the edge connector. Can't believe how such a small fault could stop the whole pcb from showing a picture but this must have been why the spot killer was lit due to no Y signal monitor.
Vector monitors require a constant changing voltage on both the X and Y inputs to satisfy the rules of the spot killer.
I see a lot of Battlezone boards that power up and run fine on the scope - so long as you adjust the volts/div to about 0.5 or something like that as there isn't enough voltage.
Generally speaking about +/-8-10v is required.
So without the Y pot in the circuit, probably very little voltage going out of the Y pin hence nothing on the monitor.
