shoestring said:Thats an interesting fault.
It was reporting back a different CRC sum at every reset.
I
suspect it's just adding the new results ( crc chk ) to the previous
before reset, RAM is still intact so it's going to do weird things
I
think it's unlikely that my testrom will find your issue. Sprite ram
only holds data associated with the sprite itself ( like what and where
it goes on the screen ) so that isn't your actual problem. I would be
looking later on in the circuit.
Have you checked the 2149 rams at 14a and 14b ? These are the line buffers.
Thanks for the new version of the rom. Working much better now
The 2149 ram was the very first thing I desoldered and socketed when I first initially looked at the PCB. I have tested both at 14a and 14b and they both pass ABI chipmaster tests
The only thing I've noted so far with the diagnostics is that some characters seem to be blank. I mention this on the video
The only other work I have done on the PCB apart from test the ram is replace the sockets on the roms C11, 12, 14, 15. I think I also tested the 083 @ C16
Purity2015-07-28 23:19:44
