Here is 0.8 - http://www.pastefile.com/ObAttV
I was unable to reproduce the problem in MAME.
I doubt 0.8 will fix the problem but I just cleaned up some of the code associated with the issue to make troubleshooting easier later.
You can see that the last error message for 10b is shown correctly in the video momentarily but then goes right off the screen as soon as I clear the scroll ram with zeros.
This is the right thing to do however, you're probably pulling a 2114 that is directly associated with the scroll ram area being utilized. So that's causing some weird problems. In 10b's case, up until this point text looks almost centered until I try clearing the scroll ram. For total failures of the ram it's obvious that this may not be a good idea but it may be ok for partial failures. I'll need to explore this further.
Edit:
My thoughts are that I should only attempt to clear RAM that is intact/error free but you would think that it shouldn't make
a difference if its pulled ?? Engineers please help!!
shoestring2015-08-08 12:05:56
