Track Field help
rascaluk
19CR
Salford mate. I saw you were in Manc. Are you connecting it to Jamma or orig? The jamma converter with this is borked and I'd love to know if it works either in an orig set up or jamma...
shoestring
159CR
rascaluk said:
Hey guys,
Anyhow, have picked up a Track & Field that I'm told was working but there are graphical issues. Sprites all seem fine but there is no  background. No track or field for that matter.
Paul
A screenshot might help.
There are 3 banks of tiles that draw the backgrounds including the text on the screen.
rascaluk
19CR
Cool. Let me grab a screenshot if I can get it to boot again.
The text was okay I think. Just no backgrounds and extra blocks on the scoreboard.
shoestring
159CR
Check the character roms @ 14h-16h and see if all the data is intact.
There is also a character lookup bipolar PROM at E15, these often go bad.
rascaluk
19CR
Woo, it's mainly working.
I resoldered all the points to the jamma converter and it looks fine now. Think it was a grounding issue.
Have no sound, just a loud hum? Any clues as to where to look for that?
Got my eproms on the way so I'll burn them up to Track & Field ones and the world is good.
Just need to get the sound going.
rascaluk
19CR
Cool. Will have a poke around it after work. I'm suspicious of the Jamma adapter as well so will have a look at that too.
The Jamma harness works fine with my Neo Geo so I know the audio is right at that end..
rascaluk
19CR
Okay so I have it making some sound, just not nice sound
That's the noise it's making, all the time.
I can adjust the volume of it with the pot so I know it's coming from the board. Any ideas boys?
rascaluk2015-08-10 21:57:16
Purity
The Oracle
2,999CR
There's not much to the soundboard
You need to check the z80, the 2764 roms, and the ram to see if they are all working ok
Do you have a logic probe?
Purity2015-08-10 22:31:02
rascaluk
19CR
Nope. Can pick one up I guess. I only vaguely know what to look for with it. Which is the z80?
That noise on the vid is constant from the second it boots. Never changes.
Purity
The Oracle
2,999CR
The z80 is the big 40 pin CPU on the top board. The other big chip is the sound chip
Constant noise means the amplifier is working ok. I suspect that you might have an issue with the sound roms. Carefully take them out of the sockets, and look to see if you have any broken legs or legs bent in half.
If they are ok, just reseat them back in the sockets and see if it makes any difference
rascaluk
19CR
Hmm. Took them out and nothing obv. Reseated them and no noise now.
Just hum. Going to have a play around with them for starters
(is the z80 the 40 pin at 3A or 9A?) Both have their serials scratched off on my board
