Trinitron
Spadge
172CR
I’m tempted to decade a spare 14” trinitron and use it in my midway cabaret. Anyone had experience of this and care to comment on it? Or is best left in its case. My search for for a 14” monitor goes on…
5,332CR
The only minor issue I can see with Trinitrons is they can look too good - as they're way better than the original monitor would've been, but that's not a biggie (and there's probably lesser 14" portable TVs out there if you want to decase something that looks a bit less perfect).
RygarR
413CR
If your cab has a dedicated monitor shroud, it's unlikely to fit round the Trinitron as well. They have a slightly different shape
robotech
823CR
I've done a few of these where decent monitors were not available or too expensive to justify using in a project cab
Decase one you may have to make a new mounting board or mounting brackets depending on the cab as the screen profile will most likely be different
You will also have to provide power to the scart pin to auto switch to the av channel when you power on
If your running a pc the retro tink VGA to scart on ebay is not bad
If your running PCBs you will need a gonbes to convert cga to VGA and then the VGA to scart converter
There may be Easyer ways but thats how I have done them in the past
The naomi has a Sony TV in it
robotech2021-12-14 16:09:06
5,332CR
A TV should be alright without any processing/frequency converter - just wire the 15kHz RGB into the SCART (preferably using a supergun that has an amplifier, although bodge resistors sort-of work in a naughty way).
I run my games on TVs via a homemade converter.
robotech
823CR
Yes I've done that too in the past made my own
From old scart cables with a few resistors in
I did one with some variable resistors in too that worked quite well
You can just copy the pinout and resistor values from a supergun and make your own as well there's not much to them tbh
The converters are the quickest way if you don't want to sit there making cables or don't have the tools/skills to make them depends how skilled you are
But as the op is asking about decasing a TV I'm gonna guess that he won't be able to make his own
robotech2021-12-14 16:35:16
