Got 2 of these (bootleg) PCB's a little while ago and neither board set booted at all, just black screened. They are a 2 board set, with a long thin daughter board to replace the originals 3 T.T-2 Taito custom chips on the CPU board. Board set 1 I realised later is missing another mini daughter board to replace the originals T.TC-4 Taito Custom chip. Board set 2 doesn't have a daughter board for this, the MCU and ROMs are on the main CPU board. Realising I'd be unable to fix board set 1 without a replacement mini daughter board I switched attention to board set 2 (another TAB Austria Bootleg by the looks of it) ..... labelled each board, A, B, C
Getting nothing but a black screen when powering this up, but activity on the cpu, ram and roms so first quick thing I could try was switching out the top 'c' board with the top 'c' board from board set 1 just in case it's a top board issue. They are physically different in size but almost identical in terms of IC's and layout ...
So connected up this board set 1 'c' board with board set 2 and got a booting game !!
So RAM check ok ! But plenty of issues ... doubling of some text, some text missing, sprites missing, don't think the backgrounds are working 100% ....
Looking at attract mode on youtube and see I'm missing a ROM CHECK and SOUND CHECK on first boot .. they may be ok just can't see them due to the text issue ..
Removed all ROMs from main board (roms on this top 'c' board are soldered straight in
) checked contents and 3 unrecognised by romident. Burned 3 new roms to replace those 3 unrecognised and popped them in but no change ....Rest of the roms checked out fine for the set (twincobr) except one of the main program ROMS has a broken leg so I cant read it but seems to be working ok in the board .. maybe !?
Anyway, also noticed the DSP32010 chip on the main board is getting VERY hot. IS this normal? (not come across one before)
So I figure I'll try and get this set of boards working fully, as at least I can see something on the screen now (when set 2's top board connected still just getting blackscreen) and if I can make 1 working game from the 2 board sets then I'll be happy with that... then also if I have a working top board I should be able to fix the original top board for set 2 ... confusing I know🤯 from here I'll stop referring to board set 1 and 2 and treat this mix of boards (below) I'm working on as just one set! MAIN BOARD (with daughter board) & TOP BOARD .. tbc
MAIN BOARD (with daughter board attached, top board removed)
TOP BOARD
TOP BOARD
