Started working on machine number 2 today and was happily getting on nicely till it started flipping raining
Thought its either Window or Driving Cab so glad I hadn't got all the window stuff outside doing that
Debated for a good while if I should fit LCD but with so many later games that really need widescreen and higher resolutions it made sense, anything 90s onwards looks great on them really, there aren't huge amount of brilliant 80's Drivers and all the good ones I have original machines or can play them in cabs with CRT so not really an issue
I've already done the other cab but now I have that to follow it makes this one easier as all the planning, guessing, measuring was done first time with some mistakes as I wasn't even sure how to fix it in, worked out okay though, so with a pile of Aluminium from the knackered Gazebo I scrapped it's being getting used for a few things
Chop the hole off the end as close as, then start with good bit, measured at 64cm and cut both upright supports
Took a fair bit of thought how I was going to fix these LCD's in place and get it to align with height and width of bezel so it's centred and what metal would I use for the fixing plate, I've still got some biggish bits of scrap metal from various things though I'd sooner save some of it for other things planned, then I had a thought, somewhere I still have a TV Wall Fixing Kit that never got used, after digging it out I measured things up and bingo cut in half it would be perfect, 1 half for each machine so this was 2nd half which I just needed to cut the corners out like the other
Then this time knowing how it's going, clamp the uprights in place and drill the holes
This way I know it's in right place, around centred but the plate hole will be slotted so that can be adjusted up/down to align with bezel. so time for the brilliant Rivet tool
This is real handy and used on many things now, got Rivet Nuts to go in the holes
Just push in the hole, and clamp it into place
Selection of bolts from stripped cars so no added costs, bolted the plate to the uprights so I can clamp that in the cab and drill the holes
