I have already posted to the Wellon forum but I thought I'd ask here too in case anyone has come across this before. Essentially, I think it has died and just outside the warranty period too
I have always had a problem with it reading 2764s, every time I read I get a different result, this only happens on 2764s, all other ROM types are OK.
Last night I thought I'd update the software to version 4.3.2, I did this, no change so I ran System Update to update the firmware (it was V9 and updated to V12). The program said "update successful, wait for green light before closing program). The link light was green and the G/E light was red, I left it like this for about an hour and it didn't change so assumed they meant the link light must be green and switched it all off.
Now the G/E light is always red no matter what I do, when I run the self test it fails all the pin voltage tests and I get no reading with a DVM when I try the voltage calibration tests. The USB side of it still seems to work OK, the program can talk to the programmer. I have jumpered JP1 which seems to take the firmware level back to V1, then re-programmed to V12 but the red light stays on the whole time and I still get no voltage at the socket.
Any ideas ?. Has anyone else updated to V12 without problems ?, (if you haven't tried already, DON'T !).
If I get a reply from Wellon I'll post here.
