Wellon VP-280 problems
cliff_poole
1,069CR
I have already posted to the Wellon forum but I thought I'd ask here too in case anyone has come across this before. Essentially, I think it has died and just outside the warranty period too
I have always had a problem with it reading 2764s, every time I read I get a different result, this only happens on 2764s, all other ROM types are OK.
Last night I thought I'd update the software to version 4.3.2, I did this, no change so I ran System Update to update the firmware (it was V9 and updated to V12). The program said "update successful, wait for green light before closing program). The link light was green and the G/E light was red, I left it like this for about an hour and it didn't change so assumed they meant the link light must be green and switched it all off.
Now the G/E light is always red no matter what I do, when I run the self test it fails all the pin voltage tests and I get no reading with a DVM when I try the voltage calibration tests. The USB side of it still seems to work OK, the program can talk to the programmer. I have jumpered JP1 which seems to take the firmware level back to V1, then re-programmed to V12 but the red light stays on the whole time and I still get no voltage at the socket.
Any ideas ?. Has anyone else updated to V12 without problems ?, (if you haven't tried already, DON'T !).
If I get a reply from Wellon I'll post here.
trm
2,877CR
Hi Cliff,
Two points - I know somebody with a VP-280 so will find out what F/W they're on. If you're out of warranty do you fancy opening it up and getting some photos? Could be that one of us has what is needed to reprogram whatever non-volatile storage is in use, or have you actually been able to get it back to base fiirmware via the jumper JP1 method? If so does it work at FW less than V12 and just not V12?
Second, I know of quite a few people who had problems with anything less than a 27128 in their VP-280's, both reading and writing. Did a fair bit of work looking into this and the pulses look good, the levels look good, everything looks good but it just doesn't seem to give reliable results reading or writing. This has been the case for at least 18+ months, so it's not related to any recent firmware revisions. This also affected multiple vendors of those EPROMS.
cheers
4,058CR
Not relevant to this thread particularly, but the TOP2005 programmer I had could never do anything useful to any of my 2764's either, and I never did work out why. COuldn't program them and would always give random results every time you read, just like the Wellon. The problem with the 'TOP' was worse though as I don't recall it ever programming anything old whatsoever. It worked fine with modern PICs and the like. Gave it away in the end.
cliff_poole
1,069CR
I will take some pictures of it later just for interests sake.
It does successfully downgrade back to V1 with the JP1 trick and the software does talk to it, it just doesn't want to output any power to the socket anymore. If I try to read a chip it justs says something like "device inserted upside down", or "over current on pin..", like there is something wrong with the pin switching. It even upgrades back to V12 successfully.
Interesting point about the TOP programmer. I recall from last night that it has something like TOP00005 screened on the top of the PCB, could be the same hardware.
cliff_poole
1,069CR
I do also have a Data I/O chiplab and of course a good old 29b (they obviously don't build them like they used to). However the Wellon was great for testing RAM and logic. I really regret touching it now, should have just carried on using it for that alone.
cliff_poole
1,069CR
Would you say that t
his 1 ohm resistor is meant to be broken in half like this ?, I'd say that it was done during manufacture as the solder looks as if it solidified after the break.
Macro
2,016CR
either way I'd probably fix it, just to see if it made a difference.
is it really 1 ohm, I would have thought the track would provide that much on it's own.
P-Man
International man of mystery
1,273CR
I managed to wire the +5v pin in the wellon socket to ground for a few minutes when i was trying to see if the logic analyser part of it worked on one of my projects.. i only realised something was wrong when i finally smelled that dissapointing smell. Now when i run the software it reports some errors, but i manully select the 280 and it will successfully still read chips. I just can't trust it though, i havn't done much more with it since that day, not sure if the programming part still works.
Oh, and 2764's have been a problem on lots of programmers over the years. Like the rest, the Wellon doesn't program them without failing. I still use my Galep-III to program them, i find that even if the programmer fails, you just burn the chip again and again until it verifies good. An analogy to think of it like is : when the programmers program the EPROM, its like they 'fill' each byte up with a certain number of bits, defined by the rom image. It can't overfill each byte, so you can program the same IC as many times as you like and it wont do anything but fill up to the specified points.
So, on my Galep-III if it fails to verify after one programming pass, i just program it again, and this usually sorts it out and the chip verifies fine. Sometimes for some chip manufacturers you have to program 3-4 times, but you get there in the end.
give it a go...
I think its a current issue, the programmable pins the programmers use to sort out which of the 40 pins in your progger socket do which can only deal with like 200ma, i think the 2764 is one of those chips that sits on or near the 200ma current draw mark for programming operations per pin, and so sometimes the progger isn't up to the job. But like i say, just burn the same chip again and you often find that does it.
