Another update for everybody.
While I have been waiting for PCBS to get made, I have spent some time adding a few more things to this tester. These will be included in the testers from now on.
1) ID Check function.
By using a simple cable to link up to the processor socket on the board, full address and data control was always possible however I have now added some extra goodies! If any of the boards eproms are read fully into the tester, it will create a .BIN file which is compatible with minipro programmers etc. Not only that it will then generate a CRC32 value and then search all of the MAME files for a match and report the game and device etc. If its not in the list, an option is given to add it in for next time.
2) When a memory dump is done, the tester will now generate a .TXT file so this can be pulled into word or whatever and printed out etc.
3) 6502 support. Has been implemented and should work but as I have no 6502 boards, I cant test this atm.
4) Signal trace.
Any of the microprocessor signals can now be traced on the board simply by typing a command in with the pin required. The tester uses a digital signature method so is accurate and also wont be affected by random digital signals on the board. Works with the board powered up or off.
There are a few other improvements made and hopefully the guys that have bought one will see them soon.
Mark
BTW I have ordered a few spare boards so if anybody else is looking for one, then PM me.
