Cheers guys, I was quite pleased it worked out so well...
I've ordered some fittings, and sadly that means I won't be getting this beast finished for some time as I've got to wait for them, but on the plus side it should be a really nice finish when it all arrives.
So, for now, I'll pimp my sticks... This is the only part of cab ownership I have any real experience with, and a part I really enjoy.
Anyone like using a stock JLF? Nah, me neither. However, the JLF can be customised like no other stick and in my opinion is the best possible experience once you have it set up to personal preference.
First things first I replaced the soft, plastic pivot with a this cool engineered stainless, mirror polished pivot, and lubed it up with some Shin-Etsu grease...
I'm yet to actually use these pivots, so can't actively recommend them yet, but I'm told they're more tactile than the softer plastic version, and of course it goes without saying that they'll be far more durable. I look forward to finding out!
Next up, I changed the loose (0.9lb) stock spring with a much stiffer 4lb spring...
I hate a loose spring, and these springs all loosen over time, but with a 4lb spring it'll stay stiifer for longer (yeah, I heard it, don't be so bloody filthy!!)
I swapped the small stock actuator for a much larger actuator to significantly shorten the throw distance...
And then simply swapped the stock square gate for an octo...
Then to complete the Euro style aesthetic, I've gone for a black aluminium shaft cover and dust washer, and a nice heavy aluminium bat top...
Then it was just a case of doing the same to the P2 stick...
A lot of this is personal preference stuff, but this is by far my favoured configuration. I have almost the exact same configuration in my fight stick...
The spring tension is very high, but it is off set by the heavy bat top, and it does loosen over time. If you find it too heavy, there is also a 2lb option. The throw distance is much smaller with the large actuator too. I personally find the small actuator and light spring of the stock stick a very loose and imprecise combination, but you'll find plenty of people who swear by them. You'll also find plenty of people who insist that Seimitsu is the only way to go, and those who will only use Korean membrane sticks. There's no right answer here.
The octo/square/round gate debate will rumble of for the ages.
I find the above combination to be extremely precise, and it's what I used when I was learning to 1cc MS1 and MS2, so I know it works a treat... for me.
