A noobs adventures in cab ownership!
ChrisBEANS
724CR
big10p said:
Looks good so far. Tip: you always need more cans than you think!
Noted!!! I think I just about got away with it here, but definitely would have preferred a second can...
I have to say, while it's far from perfect, this turned out pretty well!!
I'm pleased
ChrisBEANS
724CR
Still tons to do of course, but starting to get to a place where things can go back together...
I just hope it still works once it's reassembled :lol:
One thing I do know for sure doesn't work are the EL panels, so they'll need replacing, but I've spent quite enough lately, so they'll have to wait...
ChrisBEANS2021-05-18 12:35:30
ChrisBEANS
724CR
Cheers guys, I was quite pleased it worked out so well...
I've ordered some fittings, and sadly that means I won't be getting this beast finished for some time as I've got to wait for them, but on the plus side it should be a really nice finish when it all arrives.
So, for now, I'll pimp my sticks... This is the only part of cab ownership I have any real experience with, and a part I really enjoy.
Anyone like using a stock JLF? Nah, me neither. However, the JLF can be customised like no other stick and in my opinion is the best possible experience once you have it set up to personal preference.
First things first I replaced the soft, plastic pivot with a this cool engineered stainless, mirror polished pivot, and lubed it up with some Shin-Etsu grease...
I'm yet to actually use these pivots, so can't actively recommend them yet, but I'm told they're more tactile than the softer plastic version, and of course it goes without saying that they'll be far more durable. I look forward to finding out!
Next up, I changed the loose (0.9lb) stock spring with a much stiffer 4lb spring...
I hate a loose spring, and these springs all loosen over time, but with a 4lb spring it'll stay stiifer for longer (yeah, I heard it, don't be so bloody filthy!!)
I swapped the small stock actuator for a much larger actuator to significantly shorten the throw distance...
And then simply swapped the stock square gate for an octo...
Then to complete the Euro style aesthetic, I've gone for a black aluminium shaft cover and dust washer, and a nice heavy aluminium bat top...
Then it was just a case of doing the same to the P2 stick...
A lot of this is personal preference stuff, but this is by far my favoured configuration. I have almost the exact same configuration in my fight stick...
The spring tension is very high, but it is off set by the heavy bat top, and it does loosen over time. If you find it too heavy, there is also a 2lb option. The throw distance is much smaller with the large actuator too. I personally find the small actuator and light spring of the stock stick a very loose and imprecise combination, but you'll find plenty of people who swear by them. You'll also find plenty of people who insist that Seimitsu is the only way to go, and those who will only use Korean membrane sticks. There's no right answer here.
The octo/square/round gate debate will rumble of for the ages.
I find the above combination to be extremely precise, and it's what I used when I was learning to 1cc MS1 and MS2, so I know it works a treat... for me.
5,648CR
Does anyone actually like those square gates? I use stiffer springs and round gates, but I'm not into Street Fighter type games, where I imagine octo gates would be good. Round gates are essential for Robotron on my MAME cab.
Don't like Seimitsu sticks. They sort of ride up when pushed to full throw with force.
big10p2021-05-20 06:33:16
thegreathopper
9 (100%)
1,156CR
I only play with square gates, tried octagon and round but just feel wrong to me, I couldn’t get fire balls or dragon punches unless square, just feels right on a square.
Seimitsu LS32 are my go to sticks, can play with Sanwa but they feel a bit loose, I play 99% fighting games plus a few modernish shooters, Dodonpachi etc.
thegreathopper2021-05-20 08:43:58
ChrisBEANS
724CR
Really pleased with the next part, just simply because I was worried I wasn't going to be able to use anything other than a Euro stick...
The stock JLF clearly won't fit the CP, and it being a thick steel panel means that it'd be more trouble trying to modify the panel itself. Not to mention beyond my personal ability and the capability of any tools I have.
Fortunately, the Kowal flat plate adapter already exists, which is awesome!!
Unfortunately, because the OG sticks for these cabinets had molded ball tops (and probably didn't come apart either?), the hole in the CP is much, much larger than needed for a Japanese stick...
Meaning that once I add the vinyl CP art, there'll be a huge unsupported area around the sticks themselves. The vinyl over that usupported area will stretch and probably tear with prolonged use, making all of this an exercise in futility...
Now, we've covered that I am woefully under skilled or equipped to modify the CP.
The ideal hole for a Japanese stick is something like 20mm (maybe smaller?), and the hole in this CP is 45mm. The CP itself is 2mm thick...
Turns out, if you measure correctly, and google enough, you can find a washer that is 2mm thick, has a 45mm diameter, and a 20mm bore.
Which, once you have a nice flat plate mounted flush to the underside will sit very snugly in the hole...
And with that, I think we've successfully installed a modified Japanese stick or two into a 30 year old steel, euro CP.
I did think the mounting plate for the 2P stick might be too close to the A button, but it's all good...
Next update 'should' be me being brave enough to install the CP vinyl.
ChrisBEANS
724CR
I'll fit the viyl over the unpopulated CP.
Should be taut enough that I can then lay the washer inside the larger hole, cut out the vinyl fron the center of the washer and then mount the stick... I hope... We'll see I guess??
Amb47uk
202CR
Looking very tidy. I miss my 6 Slot.
I do recommend these for EL panels. Plug and play
http://www.neogeoledmarquee.info/product/6-slot-electrocoin-3-x-2-kit/
What I would say is the typical panels are cool white (which wasn't even a thing when these cabs were out). I requested warm white panels and they look/work great.
There are cheaper DIY ways of doing it, but IMO these are worth the cash.
Monstermug
1,807CR
ChrisBEANS said:
Monstermug said:
Lovely looking cabs. I find that taking the metal bits to the galvanisers are so much more worth it than spraying etc. Hardly cost anything and makes it look like NOS.
Oddly, I was just about to message you!!
If you’ve still got that Vendetta going perhaps I can pick your brains on the refurb stuff at the same time?
I think this has turned out ok as it’s textured paint, but the U4 parts (not the whole shell) will need sandblasting and powder coating I think...?
Yeah sorry. Been ever so busy with work still. Still trying to clear the massive backlog due to the lockdown. With paint my brother who is a car bodywork mechanic does the spraying for me. Comes out looking like a showroom car complete with reflections. But i would probably just go for the sandblasting and powder coating for durability if i didn't know him. And re galvanising any metal pieces rather than sanding it down.
I still got your Vendetta!
tt_rage
76CR
Are you planning to attach the washer somehow, or are you relying on the stickiness of the vinyl to keep it in place.
I'm thinking that joystick movement might be enough to wiggle the washer and twist the vinyl.
