Alpha1 said:Reseat the A and B boards
VectorGlow said:Try reseating the program code chips and the PALs.
Failing that, either a program code EPROM has failed, or a logic chip or a PAL.
Could also be a bad contact on one of the pins on one of the board connectors.
VectorGlow said:No worries, but silverfox makes a good point - with the power off try shorting out all three pins of EXC1 (marked on the rear of the PCB). I would hope it isn't that but it's worth a try.
VectorGlow said:Colour variance - can't beat it!![]()
You don't have access to an EPROM programmer do you? Would be worth checking out the program code EPROMs.
griffo83x said:VectorGlow said:No worries, but silverfox makes a good point - with the power off try shorting out all three pins of EXC1 (marked on the rear of the PCB). I would hope it isn't that but it's worth a try.
ok , how do i do that![]()
