alien vs predator cps2
griffo83x
30 (100%)
746CR
just powered up my phoenixed avp and was working fine
went into the options to turn the demo sounds on, when i pressed p1+p2 to exit it locked up
turned power off and back on.and is dead as dodo
any ideas anybody
THANKS
VectorGlow
34 (100%)
900CR
Try reseating the program code chips and the PALs.
Failing that, either a program code EPROM has failed, or a logic chip or a PAL.
Could also be a bad contact on one of the pins on one of the board connectors.
pulstar
41 (100%)
459CR
Alpha1 said:
Reseat the A and B boards
This happened to me on my SFA board - was playing and it just locked up and didn't work again, even on other mobos. Other games worked fine on the mobo but the game didn't. There was something in the connector. Cleaned it out and then it worked fine again.
griffo83x
30 (100%)
746CR
cheers phil, i tried reaseating everything but made no difference, looks like another in the pile for you to look at
griffo83x2014-03-07 18:28:19
VectorGlow
34 (100%)
900CR
No worries, but silverfox makes a good point - with the power off try shorting out all three pins of EXC1 (marked on the rear of the PCB). I would hope it isn't that but it's worth a try.
griffo83x
30 (100%)
746CR
ok , how do i do that
VectorGlow
34 (100%)
900CR
Colour variance - can't beat it!
You don't have access to an EPROM programmer do you? Would be worth checking out the program code EPROMs.
AeroCityMayor
Entity formerly known as alien_mame
100CR
It's EXC3 above the PAL section and I use a packet of polo mints.
HTH
Cheers,
Ralph.
AeroCityMayor2014-03-10 23:13:23
