Any interest in a Group buy in wigan 3x noir?
5,198CR
Thanks for looking.
LG monitors seem to be the go-to: -
Whats the specs of the original Monitors, They only 720P anyway aren't they, which kinda sucks when using a PC with Multi games, really need full HD Minimum
I thinking It could be good for Gun Games with my 2 Sinden, need something that's going to work well with those if the screen is right angle, be pretty well setup then for playing most games
5,198CR
Random question for you knowledgable folks: -
These are Japanese cabs that run on 100v, yes?
Can I put a spare Naomi universal AC transformer internally in the cab to convert 240ac down to 100? I’ve got lots of them, either this Naomi one or several from Daytona twins
I assume there’s space inside?
I was wondering this too as I've got 3 spare transformers from various sega cabs 2 out of the Twin Driver after LCD Swap which is good lol
Chihiro
920CR
Sanwa were 720P & the Wei-Ya's which are in most were 1065p which can be fussy with inputs, I have a LG Ultragear 2k in mine now.
Stock monitors are so old they didn't even have led back lights only flo tubes.
The Namco STD connect pcb can be troublesome & give odd sound newer Grigio units done away with it & only have one psu with direct sound from the amp & JVS.
channel27
1,342CR
Something like an LG 32GN600-B?
(32", non-curved, 2K)
What's the model of yours, if you can remember, please?
eliotcole
988CR
Swap each of those for a Dreamcast powersupply. It literally does the exact same thing but with 110v/240v independence. 🙂
Plus, any replacement monitor is likely to be 240v ... things get easier for all that voltage wank with LCD/LED/OLED panels. 🙂
It depends what I end up putting in there tbh.
I guess the IO board needs 12 and 5v from somewhere and the existing PSU(s) run on 100v. If they're knackered I've got a Sun PSU to put in there but that'll also run on 100v.
Or I could just use a 240v PC ATX PSU
7,888CR
To be honest ..
I was never going to use any of this stock stuff ..
Happy to use a ps4/3 etc .. with a brooks .. and add my own amp.
I guess T7 es3
But I could just chuck a technoparrot pc in this ?
Crazy_1201
90CR
To be honest ..
I guess T7 es3
Artax multi with brooks boards or the gp2040-ce. Can run on any pc with decent specs and gpu.
The main amp and the jvs io are mounted in the back btw where the monitor connections can be seen.
Chihiro
920CR
I found the amp to be very good in my Noir, I use a PS4 in mine with a couple of brooks boards.
Amp was good the std connect pcb not so but a easy fix I still have the old one if anyone gets stuck.
I had my amp re-capped though just for preventative maintenance.
I only use the 12v amp for the sound, 24v oem monitor & lit move strip (faulty), 3.3v & 5v (JVS) not used.
Added led lights strips for my lit instruction space.
If anyone doesn't fancy getting their cp surround powder coated I used this paint & it turned out pretty can for a rattle can.
