Any Linux people help
8,290CR
Ok …. New day fresh eyes ..
Just noticed that there is an option on the github Lindbergh emulator page
Top of page to download Complete code zip.
Which I did not do!
So I think now that I was trying to run a makefile with out all the required object,
Source code, sub directory etc….
Doh!
Will start again tonight!
Mc-Q
1,450CR
if it still fails:
what exactly is the error?
and are you using 32 or 64bit o.s.?
and did you install compilers & stuff.
explain from the begining.
it will make things a lot faster.
i'll compile it myself to check.
8,290CR
if it still fails:
Thanks Mc-Q.
I’m running 64bit Ubuntu ..
And win 10. On separate hard drives.
Nvidia gpu 960 gtx
Amd cpu .. ( Lindbergh wants intel but looking at the updates it seems this was rectified..
So the error I was getting was
No target , src,, when attempting to run the makefile..
Which is the last thing on the readme
Guide to do.
I think it maybe because I haven’t downloaded the complete zip…
And unpacked it say in a file named
/Lindbergh-loader?
I was copy pasting the command lines
From the GitHub pages .. proberbly a very noob thing to have done☺️🥹
8,290CR
Mc-Q
1,450CR
if you right-click the file you can "extract archive here, autodetect subfolder"
go into the folder it created so you see the makefile and rightclick the screen - then "open terminal here"
now presuming you already went through the instructions about
Dependencies
First make sure you have up-to-date NVIDIA drivers and then install the following:
sudo dpkg --add-architecture i386
sudo apt update
sudo apt install gcc-multilib
sudo apt install build-essential
sudo apt install freeglut3:i386
sudo apt install freeglut3-dev:i386
sudo apt install libglew-dev
sudo apt install xorg-dev
sudo apt install libopenal1:i386 libopenal-dev:i386
sudo apt install libalut-dev:i386 // You will need to find libalut-dev:i386, libalut0:i386 and multiarch-support:i386 fromsudo apt install libxmu6:i386
sudo apt install libstdc++5:i386
sudo apt install libasound2-dev:i386
For Ubuntu 22.04 and above you’ll need to download manually from Xenial.
wget -q http://launchpadlibrarian.net/534757982/multiarch-support_2.23-0ubuntu11.3_i386.deb \
&& dpkg -i multiarch-support_2.23-0ubuntu11.3_i386.deb
wget -q http://launchpadlibrarian.net/184146495/libalut0_1.1.0-5_i386.deb \
&& dpkg -i libalut0_1.1.0-5_i386.deb
wget -q http://launchpadlibrarian.net/184146496/libalut-dev_1.1.0-5_i386.deb \
&& dpkg -i libalut-dev_1.1.0-5_i386.deb
Note: The project has been tested to work on Ubuntu 22.04, and doesn’t currently work on Ubuntu 23.10. Multiple packages such as
freeglut3:i386 are not available anymore on Debian Trixxie or Ubuntu 23.10.
you should be good to type "make"
8,290CR
😎👍☺️ that’s cool ..
Yes I updated my nvidia drivers
Fingers crossed this could be ok
Thanks for the help.
8,290CR
😎👍☺️ that’s cool ..
I have build now ..
I tried ./Lindbergh and received
No game found here ..
So I think I have managed to run the makefile . And I have the build.
I have no games so unable to test it
But can I run it in test mode
I tried ./Lindbergh -t
No dice I was just wondering if I can load up to the Lindbergh splash screen without a game
8,290CR
I don’t know how to say this but
Ffs!
Linux or my hdd has gone screwy on me !
I have loaded some Lindbergh game files onto my windows hdd..
Then I was going to drag them across to the Linux drive ..
But I’m now greeted with
/dev/sda2 a file system with errors ,check forced.
Inodes that were part of a corrupt orphan linked list found.
/dev/sda2 unexpected inconsistency’s run tack manually ..
The root file system on/dev/sda2 required a manual fsck..
I have tried fsck /dev/sda2
& I have tried. fsck -a /dev/sda2
? Is my hdd corrupted/ fcked!?
8,290CR
Fresh install ..
Now I can’t get into root user
Password not recognised ..
Must have hit a wrong character both times ? When setting my password ?
Really
Mc-Q
1,450CR
lol
make sure your using EXT4 filesystem and dont pull the plug - make sure you shutdown clean.
but the inode thing sounds like a bad drive or cable or something related because normally corrupt files are purged at boot from a bad powerdown
8,290CR
lol
Yeh I will most likely start on a new drive as soon as I have worked out the install process and have a game up & running ..
Problem I now have is knowing where to put what?
Read me mentions place game in your game file ?
I don’t see a game file do I need to creat a new file called game ?
Then it says place game.elf ?
I don’t see any game.elf in either of my
Or a game I downloaded off the net last night..
i just started with a fresh install from usb boot .. after the indode bad file system. Error..
And I have the whole install of Linux
Ubuntu & the Lindbergh - loader installation down to about 15 mins ..
So it’s not to bad..
Just got to work out where to drop game files and game.elf and the
Lindbergh loader file
then sucsesfully run ./Lindbergh
Now I’m @ 6 evenings I will persevere
Mc-Q
1,450CR
elf is the Linux equiv of EXE but the extension is usually not used.
i dont have any Lind games to examine - maybe i will pull something small down later
btw, do you have any real lind stuff?
i'm looking to borrow or buy the small board with the pic socket & dipswitches so i can draw a schematic.
i have a couple of Lind motherboards without thet board. :(
