How long you want it for to draw schimaticYea I have 3
I can let you burrow it
What does it look like ?you need the CF image because it's the boot-drive
thats the CF image.DISK_IMAGE_READONLY("mda-c0004a_revb_lindyellow_v2.4.20_mvl31a_boot_2.01"
Cheers man will take a lookfrom mame:
thats the CF image.
make
cp build/* ~/the-house-of-the-dead-4/disk0/elf/.
cd ~/the-house-of-the-dead-4/disk0/elf
./lindbergh
Right ok ..so this?
those are seperate lines,
so type "make" to build the code,
"cp" means copy, so presumably after typing make there is a build folder.
the wavy line means your home folder, so that line will copy the contents of the build tolder to a folder in your home directory called "/the-house-of-the-dead-4/disk0/elf/"
cd = change directory and will put you in that location.
"./" means run the file - in this case a file called "lindberg"
you obviously need the game decompressed and have to put it in there correctly or the emulator wont find it
👍Now I’m getting permission denied …
I think this maybe as I need to be running as a user groupe?
😀. Yeh it says “ignored the 32 bit dependency”. so maybe that part has had a work around in the loader?look at the bit about permisions and dialout or something like that.
the software wants access to the serial ports
as for 32 - did you do the dependency bit about multi-something?
the 32 bit compiler stuff?
Lindberg is 32bit and you and everybody else is running 64bit Linux
sorry thats vague - i need to go read the readme again![]()
Yeh I am 1 credit on there..Checking on the Arcade Projects thread (assuming you are 1credit on there) It says early on that you have to patch the games to get round the security in them, which his loader does not do.
Have you done this?
