Any Linux people help
8,309CR
Bobby dilly / author of the loader
Says some games require a file from the CF card ? It I don’t think Im
Missing from my games although
I now think I have the decrypted game files for the multi 🤨
Most files are .dat
8,309CR
Im hitting a brick wall
With this!
I have the CF mda c0004a rev b file ..
I dropped it into the build file..
What I don’t have is any directory’s
House of the dead 4/disk0/elf/.
Which it mentions in the make file ?
Also copy contents of build into game directory and run?
I don’t have a game directory ?
I run make file
But it ends with home/dan/House of the dead 4/disk0/elf/. Is not a directly.
Would love to know
Where I am going wrong ?
Is it safe to say my make file is not creating the sub file directory’s ?
I’m also getting a -
Gcc -m32 -g o0 fpic -m32 -wall -werror -wno -unused variable -wno unused function
-c -o src Lindbergh baseboard.c
Mc-Q
1,450CR
so this?
make
cp build/* ~/the-house-of-the-dead-4/disk0/elf/.
cd ~/the-house-of-the-dead-4/disk0/elf
./lindbergh
those are seperate lines,
so type "make" to build the code,
"cp" means copy, so presumably after typing make there is a build folder.
the wavy line means your home folder, so that line will copy the contents of the build tolder to a folder in your home directory called "/the-house-of-the-dead-4/disk0/elf/"
cd = change directory and will put you in that location.
"./" means run the file - in this case a file called "lindberg"
you obviously need the game decompressed and have to put it in there correctly or the emulator wont find it
8,309CR
so this?
Right ok ..
I will try this ..
I have the build folder ..
I don’t have any house of the dead folder/disk0/elf/.Lindbergh
8,309CR
Im getting wrong elf class elf class32 ignored sh:1 .vt3_lindberfh permission denied
😊👍. I feel like I have made some progress so that’s cool..
At least tonight I have the folder structure correct now 👍 thanks
Mc-Q
1,450CR
look at the bit about permisions and dialout or something like that.
the software wants access to the serial ports
as for 32 - did you do the dependency bit about multi-something?
the 32 bit compiler stuff?
Lindberg is 32bit and you and everybody else is running 64bit Linux :)
sorry thats vague - i need to go read the readme again :D
8,309CR
😀. Yeh it says “ignored the 32 bit dependency”. so maybe that part has had a work around in the loader?
Yes I don’t know if i complied the dial out part successfully ..
I was unable to get into Suso .. because
It was not recognising my password.
So I would then drop back onto su root
Root #. And bash the dial out script
But nothing loaded .
It just returned to the root# ..
I am wondering if I can get into sudo later then run the ./Lindbergh it may give me permission
I have vitual tennis 3 in elf folder
I open a terminal and ./Lindbergh
And I get “VT3_lindbergh “So it is seeing the game 😚☺️. I’m happy I have got this far 👍
If I can make progress everyday I will get there eventually …
I have an intel pc ..
I will load a 32 bit OS once I figure out how to load a game🤣
Fantazia2
2,246CR
Checking on the Arcade Projects thread (assuming you are 1credit on there) It says early on that you have to patch the games to get round the security in them, which his loader does not do.
Have you done this?
8,309CR
Have you done this?
Yeh I am 1 credit on there..
Nope I haven’t patched any games ..
But I have the decrypted games for
Technoparrot
And the Lindbergh multi decrypted games from Internet archive.
I pulled down a couple games last night
So I could try patching them tonight
