Dependencies
First make sure you have up-to-date NVIDIA drivers and then install the following:
sudo dpkg --add-architecture i386
sudo apt update
sudo apt install gcc-multilib
sudo apt install build-essential
sudo apt install freeglut3:i386
sudo apt install freeglut3-dev:i386
sudo apt install libglew-dev
sudo apt install xorg-dev
sudo apt install libopenal1:i386 libopenal-dev:i386
sudo apt install libalut-dev:i386 // You will need to find libalut-dev:i386, libalut0:i386 and multiarch-support:i386 fromsudo apt install libxmu6:i386
sudo apt install libstdc++5:i386
sudo apt install libasound2-dev:i386
For Ubuntu 22.04 and above you’ll need to download manually from Xenial.
wget -q
http://launchpadlibrarian.net/534757982/multiarch-support_2.23-0ubuntu11.3_i386.deb \
&& dpkg -i multiarch-support_2.23-0ubuntu11.3_i386.deb
wget -q
http://launchpadlibrarian.net/184146495/libalut0_1.1.0-5_i386.deb \
&& dpkg -i libalut0_1.1.0-5_i386.deb
wget -q
http://launchpadlibrarian.net/184146496/libalut-dev_1.1.0-5_i386.deb \
&& dpkg -i libalut-dev_1.1.0-5_i386.deb
Note: The project has been tested to work on Ubuntu 22.04, and doesn’t currently work on Ubuntu 23.10. Multiple packages such as
freeglut3:i386 are not available anymore on Debian Trixxie or Ubuntu 23.10.
