Purity
The Oracle
2,998CR
Nes4life said:
Thanks Purity! The buttons on my LCD now work properly!
No worries fella! Glad someone got some use out of it
I didn't want to edit the main program, but it might be worth putting in ranges for buttons rather than specific values so it is more compatible with most LCD modules?
Nes4life
1,116CR
Finally got the first prototype of the Pacland tests running today and happy to say it found a dead RAM for me. I'm going to replace it tomorrow and see where it leads me next.
Big thanks to Paul for checking my code and patiently explaining stuff to me as I get up to speed with the ICT. Got a number of PCBs to play with so should be able to fully test the tester
Purity
The Oracle
2,998CR
Cool. Was going to see if I could adapt the Champ Sprint Code to test a Paperboy PCB over the weekend. Should be fairly straightforward ?? :)
Purity2017-05-09 00:17:57
Nes4life
1,116CR
Anyone else need another core pcb (not the header) with no resistors in the design? Would someone who knows how to do these things edit the core pcb file, replace all the resistors with traces and make the file available please?
Anyone else need a 8080 header or 68000 header? If these’s any of these for sale I’d like one but otherwise I’d be happy to do or participate in a run on all of these (and hand them out at the Arcade Club meet if there’s time).Nes4life2017-10-05 09:12:08
4,054CR
Rather than alter the design of the PCB so that you have a bespoke one just for a single processor, why not add either wire links or 0 ohm resistors? Granted, you still need to order some in either case but at least you don't have to worry about changing the design.
Nes4life
1,116CR
Ah, my thoughts were the opposite to avoid soldering time. Why order a pcb where I’ll need to solder in many many patch wires when I can just alter the design and order them with no need to patch. I’m the 2nd person that I know of to come across this issue (and on a different pcb) so thought maybe it was something we could all do with. But yeah, if it’s tricky to alter the file then I could order a standard pcb and do the solder work.Nes4life2017-10-05 10:46:57
Judder
991CR
Maybe just drop Paul a quick email / PM and ask him if he would add a version without the resistor requirements? - he's a very nice guy
I know that he has been optimising the design over time but probably like me has been off doing other projects for a while
If not I can ask him, or make the changes for you - IIRC the design is in Eagle and Paul shared the source board design files
4,054CR
Yeah, I just had a nose at page one. I'd forgotten how many resistors were on this thing
It isn't difficult to make the changes in Eagle but I've not even so much as looked at anything Arcade related for months if not years now. This was probably the last involvement i had in the 'scene'.
NoellEagan
3CR
Hi..i am a new user here. In my case i get a motherboard knocked up soonish which will take the arduino
as a daughter board and have a row of connectors so other processor
adapters can be plugged in. I have tried to use the video library to
display info on a monitor but the pins used are slap bang in the middle
of the pins I use so shelved that for time being. Hooks up to a laptop
with a terminal program controlling it. Have to say it works well and
has helped me find some awkward faults. Its on going atm. I did make a
program which clips over logic chips and also tests chips in-circuit.
one-stop pcb
NoellEagan2022-03-13 20:50:10
Nes4life
1,116CR
Judder
991CR
Purity said:
Basically I purchased a SainSmart Arduino and a compatible LCD module. The LCD was labelled "Drive the Future". I think this is classed as a "Robot" shield
I compiled the code and uploaded it as per Paul's instructions but I could not get the keys to work apart from "Right" and "Reset". I initally thought the shield was faulty however I tested this out and it was ok.
I had the similar problem re-testing mine recently with a SainSmart clone LCD and button display and found a potentially cleaner way to fix this was to widen the threshold value in the DFR_Key.cpp file in libraries/DFR_Key/DFR_Key.cpp
As the analogue values on the keys are actually quite a way apart from each other (approx. 250), we should be able to have 'bands' where each key is successfully detected, even if you are using a clone shield versus an original
static int DEFAULT_THRESHOLD = 25;
BTW Right is value 0 so this will always work, and Reset is hard wired, so if only your Right button is working and your Reset, then this is probably why
On another note I'm thinking of attempting Slap Fight with the Z80 driver as I have a board that's playing up of that at the moment - it's got 2 x Z80s - one of the main game and one for the sound driver so focusing on the main one first makes sense
If anyone else wants to join in, drop me a PM or join the thread
Bytestorm
60CR
Thinking about ordering these probes and the shield from oshpark.
The versions submitted there, are they all the latest and the greatest?
Arduino ICT Probe 68000 V1.00 (Shared on March 29th, 2017 15:22)
Arduino/Fluke DIL40 Probe V1.01 (Shared on March 13th, 2014 15:24) (usable with z80/6809?)
Arduinio In Circuit Test Shield V1.10 (Shared on September 13th, 2014 18:50)
My main goal is to use them for z80,6809,68000 boards.
I already have a spare arduino 2560 r3 + display board that I thought I could try :)
Should I order away or anything new on the way/updates to the pcbs?
Thanks!
