Astro fighter
Lurch666
21 (100%)
4,517CR
Correct.
Found out by removing the rom daughterboard just before i went to work.
The -5 and +12 each come from their respective regulators.
Is it possible to generate -5 and +12V from +5V? My electronics knowledge doesn't go that far.
While at work i figured my best plan of action is to first backup the eproms then remove everything that needs -5 and +12 (hopefully it's just the CPU and eproms but memory might need it too) if I can then I can power up the board and check the -5 and +12V is being generated since if they are not it might damage the chips that need it.
Normally like to just build an adaptor,get the video connected and see what comes up but need to be more careful with these older boards.
Lurch666
21 (100%)
4,517CR
OK removed the roms and they are the only chips that need -5 and +12 so powered on the board.
Not seeing a good composite signal from pin 4 and not getting the expected voltages for the 2708 roms.
CPU is active though.
Been following the connections and even though the tracks are thin I'm thinking pins 15 and 16 of the edge connector are connected to +35V.
@Body pop. From your pictures there appear to be two light blue wires going into pins 15 and 16 of the connector that goes to the main PCB.
Can you verify that they are going to those pins and see what the other ends are connected to?
Body pop
24 (100%)
1,266CR
They go into that connector plug and change to red
Then into that transformer ,there’s another one of these similar looking for monitor in one of the pics
Lurch666
21 (100%)
4,517CR
That verifies my theory that there is AC voltage going into pins 15 and 16 of the PCB.
I'm used to figuring out the connections of the PCB that have power via the thickness of the traces but here the traces that carry this power are the standard thin ones.
I've decided to remove the sound board (will worry about sound after I get everything else working) and supply -5V and +12V direct to the rom daughterboard from my PSU to make sure it gets the correct voltage.
Lurch666
21 (100%)
4,517CR
Forgot to mention I read all the roms and they seem to have data on them.
Can't tell if they are all good but could see text in the 1st rom and there are graphics stored on roms 9 and 10.
Romident doesn't recognize them though so maybe this is a unique version since it's working on a crash.
I'm thinking it's going to be a black & white cut down version.
Lurch666
21 (100%)
4,517CR
Progress.
I wired up the correct voltage but couldn't get a picture on any of my test Tvs using composite so ended up using the monitor in my cab.
By taking the video and sync signal from the board before they were mixed then connecting the video signal to the green input and sync to the monitor sync I got this.
The cab monitor seems to be able to sync anything and I have full adjustment over the horizontal and vertical settings.
So the graphics roms are active but the other roms and CPU don't seem to be doing anything after a quick test.
This is going to be a bit difficult since I can't use my test gear when the PCB is plugged into the cab since they are in different places.
Anyway it's outputting something and shows that there is possibly monitor problems with the cab since the picture shows only a circle of garbage in the opening post.
Now to see why it's not running.
Lurch666
21 (100%)
4,517CR
Has this cab ever worked?
Just wondering because I found out that if I remove the roms the CPU shows activity (well I'm getting static waveforms on the data and address lines where before data and address lines just sat high or low).
Noticed that chip select was low on rom 4 so I tried swapping the first four roms around and got the same waveforms but no change on the screen.
Don't know if it's down to the CPU looping because of the wrong roms or maybe some roms are bad.
So wondering if they could have been swapped around at some point.
Body pop
24 (100%)
1,266CR
It’s not worked since I’ve had it
I got it from a guy who was about to make a mame cab out of it
The guy got it from a friend and who got it as a wedding present when it was new or near new !
Anything is possible I suppose ,with it being over 40 years old ,someone could of messed with the roms
Everything In it just looks so untouched and unhacked to my untrained eye
Lurch666
21 (100%)
4,517CR
So now I'm trying to figure out if it can run code.
Normally I would just burn a set of roms from mame to test but since this game is not in mame and there's no info out there apart from the crash manual about it I was hoping to write a little 6502 to put some letter X on the screen.
According to the crash manual screen memory starts at $4000 so it should be easy to put $29 into the first few locations and since the video circuit seems to be working I would see some letter X appear on my screen in the top corner.
But I don't know enough about 6502 or the memory mapping of this game to figure out where to put the code.
I was originally thinking of putting the code at the start of rom 1 but looking on the net a 6502 has a reset vector stored at location $FFFC & $FFFD but since I don't know which rom is mapped where I can't see where the CPU will start running it's code.
The rom addresses are $1000-$1FFF and $F000-$FFF7 with $FFF8-$FFFF being the interrupt and reset vectors so I assume I would need to know the value of those memory locations to know where to put my bit of code.
Looking at the roms the eprom labled 1 has visible text in it (high score,fuel etc) but if I disassemble it the 1st part it doesn't look like proper 6502 code to me.
I thought about just using the crash roms on it but it looks like it's been modified so the memory mapping could be different.
So does anyone know 6502 who could help?
Lurch666
21 (100%)
4,517CR
So I tried to be clever and made a rom containing NOP instruction but with the code at the end to put the Xs on the screen hoping if I put the eprom in the right place on the PCB to catch the code running it would just jump past the NOP instructions till it got to my code then put the Xs up but it doesn't work.
I tried with the test rom in positions 1,2,3,4,5 and 6.
This is the code I put at the end of the eprom:
A9 29 LDA #$29
8D 00 40 STA $4000
8D 01 40 STA $4001
8D 02 40 STA $4002
8D 03 40 STA $4003
So still none the wiser but with my test rom in place of rom 4 I'm seeing changes to the activity of the address and data lines instead of the static activity I normally see.
@philmurr:Sent the images via PM and also included the test rom I did (1testX.bin).
Lurch666
21 (100%)
4,517CR
Just tried my test rom on crash in mame and even though it doesn't show the random garbage that the real PCB shows I got four different characters in the top corner like expected.
They were squares instead of X but changing the value I was sending to the screen resulted in the number 4 appearing in the first four postions so my theory seems to be good so now I'm going to assume that the astro fighter isn't running code.
I'll check the data and address buses to see if I can find anything amiss.
Lurch666
21 (100%)
4,517CR
Can you see it?
I missed it because I was looking at the top of the screen.
But the screen is rotated.....
Look in the bottom left corner.
It's a row of squares. It looks like my test code actually worked but I was looking in the wrong place.
It should be a row of four Xs but when I tested on the crash in mame I got squares in he top right corner because in mame the screen is horizontal not vertical like on my cab.
So it looks like the PCB is running code.
So the next things to check are the roms and the ram.
Unfortunately there's no way to check if the roms have the correct code unless I can find someone with this same PCB running astro fighter.
The ram is 2111 and of course it's rare and expensive.
So shouting out there for anyone who might have this same crash PCB running astro fighter.
I'll ask on KLOV as well.
EDIT:Forgot that my slice will test 2111 ram so at least I can see if the ram is good.
Lurch6662021-06-01 19:04:13
jonno5
8CR
Hi, I have lurked the forum for a year or two (on or off!) but today I saw the Astro Fighter thread and decided to sign up. I have a cocktail Astro Fighter in a mostly disassembled state. I'm not sure if it's of any use to this repair (given it's a different machine) but I thought I'd offer if you can think of anything. I might have the wiring diagram knocking around somewhere should that help. My machine is the triple board one mentioned earlier in the thread. Best of luck with the repair!
jonno5
8CR
Lurch, thanks for the link to your astro fighter repair thread.. it seems you went thru hell on that one! I think it'll come in handy for me at some stage. Best of luck with this one.
