Astro fighter
Lurch666
21 (100%)
4,518CR
So I've been poking around this PCB trying to figure it out. Trying various things to see how the rom addressing works and checking a few chips including the 2111 ram chips with my slice.
In a 'how the hell did I not spot this earlier' moment I have just noticed that two ram chips are missing.
If you look at the crash schematics there are four 2111 ram chips but on this PCB there are only two-you can see two empty places where the other ram chips would have gone in the middle of the main PCB.
Now is this just because it's a bootleg so didn't need all four ram chips (but since astro fighter is a more complex game than crash I'm doubting that) or have those chips been removed at some point?
The plot thickens.
Body pop
24 (100%)
1,266CR
Very interesting ,maybe someone had started repairing it back in the day ?
Would you be likely to still get the image your getting with them removed ?
Lurch666
21 (100%)
4,518CR
That ram is the ram that the CPU uses and for most repairs if the CPU ram is bad then the game doesn't run.
If the ram has been removed it's been done in very professional manner since there are not the usual signs of removal-this is why I'm leaning towards it not being needed.
But like I said before I would have thought a more complex game would need more ram but maybe they figured a way around that and saved the cost of expensive ram chips.
Lurch666
21 (100%)
4,518CR
Got to admit I was close to admitting defeat with this one.
Various tests were inconclusive as to if it was successfully running code.
I had no idea if it was a fault or just my poor understanding of 6502 machine code,this PCB and all it's modifications.
It's hard to try and fix a PCB if you have no way of knowing if the roms contain good code or not-it could have been that there was no fault on the PCB and the fault was in the code.
I had put it to one side to let my brain mull over what I had found out about this PCB and see if I could figure out what to try next.
I finally got round to fixing and converting an old scrap scramble bootleg into a super cobra following Philmurrs great post on here detailing the modifications required.
After sorting that out I still had no idea how to proceed with this PCB. I have a bootleg wonderboy on it's way so wanted to either make some progress or admit defeat with this one.
I put it on my bench and used my standard technique of 'staring at the PCB hoping for inspiration' and I noticed a socketed 74S474 at 14D. No idea what that chip does but since it was hidden under the sound PCB I had ignored it till now (bet you can all guess where this is going) so I pulled it and the legs were straight but black from oxidation so a quick scrape with my scalpel cleaned them up and I connected the board to my cab and gave it a try.
As usual I just got a screen of garbage like I showed earlier but I had swapped the order of the roms on the daughter board so I tried them in the original order and got this:
Activity at last!
Hard to see whats happening but it's definitely running code.
Next I swapped the two roms that contain the graphic code and got this.....
Ladies and gentlemen I present for (as far as I can see) the first video EVER of this version of this game working:
A thing of beauty isn't it?
Next will wire up the controls to see if they work.
Last I will tackle the sound-that's going to be tricky because of the way the power works but I should be able to figure something out.
Body pop
24 (100%)
1,266CR
That’s totally amazing !
Thanks for not giving up ,you’ve saved something that was gone forever
I want to put the coloured plastic strips against this video now !
Great work !
Vamino
Insert coin(s)
2,700CR
Fantastic job mate!
I loved Astro Fighter back in the day, who knew there was another version like this!
Lurch666
21 (100%)
4,518CR
Controls and sound appear to be OK although since I have never heard this one playing before I don't know if any sounds are missing.
The game does seem buggy though.
It's a lot harder than the normal astro fighter since everything you die your ship gets moved higher up the screen-that only happened in the original if you let enemy ships past.
1st time playing and the 1st set of ships sped up to a stupid speed but that didn't happen on subsequent games.
Managed to loop the game twice now but after the 1st time the game locked after the 2nd loop and the 2nd time the game went back to demo mode after the 2nd loop.
I'm thinking this could just be buggy code but will have to play more and see.
philmurr
48 (100%)
2,378CR
Nice work Lurch, from a brief look at the code it seems to be quite a hefty rewrite of the DECO Astro Fighter code and not just a slight modification, you've unearthed something new here
Guess you'll be needing a multigame now
Lurch666
21 (100%)
4,518CR
No idea since I still don't know if the code on the roms is good.
A single bit out of place could cause problems and with the age of the eproms that's a possibility.
I burned a new set of roms while trying to get this working so I'll try again tomorrow with different roms in and video the results to see if there's any consistency to the problems.
Any chance of asking the dude you got it from if they remember any problems like resets after the second loop?
Lurch666
21 (100%)
4,518CR
Just played again this morning-no video since I'm still in my dressing gown.......
Beat the refuel boss twice and it just went back to demo mode again. Tried with fresh roms but no difference.
New things I found out.
When you put a coin in there is no 'press start' or anything like that. The demo just freezes but a digit will appear in the to right corner that's the amount of credits you have.
When playing two player it just instantly switches between players and the only indication of which player is playing is 'player 1' or 'player 2' that's above the scores flashes.
No game over when you lose your last life or run out of fuel it's just straight back into demo.
Looking through the code I noticed some text in (I presume) Italian and found out there's a dip setting to switch the on screen text to Italian (player-1,high score etc).
Since the original astro fighter is 12K and this game is 6K+2K graphics it's no wonder it's so cut down.
The only other thing to try is playing in the other language and see if that lets me past round 2 but I'm thinking this is prototype code that never saw the light of day.
The fact that the game resets after two rounds tells me this isn't hardware related or it would be resetting in other places but I have no way to be sure.
I can either send this PCB back as is now or hold onto it for a while and maybe I can think of something else to try but there might be nothing to fix.
big10p
Coins detected in pocket!
6,092CR
Congrats on the fix. Bear in mind this is a boot, so they probably didn't put a huge effort into the coding or bug testing. :D
Lurch666
21 (100%)
4,518CR
New discovery:
Just been playing with the dip settings (dip 4 is language) and found a setting (dip 3 on I think) that caused the game to end after completing the 1st loop so maybe there's a combination that doesn't cause the game to end after a certain amount of loops.
Body pop
24 (100%)
1,266CR
You really do know that pcb inside out now !
The guy I got the cab off ,had got it from his dads friend .who got it as a wedding present !
I will contact him and see if he can contact him and if he remembers anything .id be doubtful of finding anything out
But since you’ve preformed miracles ,maybe there’s a chance :)
Really really incredible work there
Lurch666
21 (100%)
4,518CR
So as far as I can figure out the dips work like this
1-1 or 2 coins per credit
2-3 or 5 lives
3-slow or fast fuel usage
4-English or Italian
5-few or lots of enemy shots
6-game ends after 1 or 2 rounds.
When the game ends after finishing either one loop or two depending on the setting of switch 6 it still keeps the scores and high score so it's not the game crashing or watchdogging-I don't even think there is any watchdog.
It's extremely frustrating having a game like this that seems to be set to finish after a short time but it's looks like it's coded that way otherwise there wouldn't be a setting to change it.
With fast fuel usage and lots of enemy shots this behaviour can be hidden due to the fact it's practically impossible to loop the game twice in that state.
Lurch6662021-06-12 10:49:00
Body pop
24 (100%)
1,266CR
Crazy crazy stuff
It’s been made to be a total coin muncher ,by the sounds of it
If it’s near impossible to beat ,who would of known any different ?
Those guys with the super playing skills ,would of kept feeding it and not taking no for answer
So leave it on fast fuel usage and lots of enemy shots and who would know the coding wasn’t finished
I find that information quite exciting
Thanks again for putting so much effort into this
Lurch666
21 (100%)
4,518CR
So here's your options.
I could send this PCB back as is or I could desolder the two ram chips and socket them before I send it back.
There's a (slim) possibility it could be a ram error causing it to stop playing after one or two loops but since I don't have any spare 2111 ram and they are expensive it could be a waste of time and money trying to find out and you might be happy with the game as is.
If the ram is in a socket and in the future you want to try replacing it it will be a simple case of you unplugging the old ram and replacing it with new.
I'm going away on holiday next week so could do with getting the PCB back to you this week.
