Astro fighter
Body pop
24 (100%)
1,266CR
Yes please if you don’t mind desoldering them so they are socketed
That would be great !
I have a load of ram here .not sure if they are the same ones used for defender
But that number sounds familiar
Lurch666
21 (100%)
4,517CR
Socketed the ram and now-
It's not working.
DAMMIT!
Checked my work and the rest of the board but it's back to square one.
I was thinking maybe the ram didn't survive being removed.
Looked for replacement ram and discovered that the MK14 used 9111 ram which is the same as 2111 and I happen to have built a replica MK14 a few years ago so I used the ram from that and still nothing.
I just don't understand it-all the connections are good for the ram and there are no shorts so why has it stopped working?
Lurch666
21 (100%)
4,517CR
*WHEW*
Back working again.
After a frantic search I found one of the modification wires had come loose while I was sorting out the ram.
Fixing that didn't get the game back until I had fixed (again) the socket for the sound board since I had removed and replaced the sound daughter board as part of troubleshooting.
The sockets are showing their age but as long as the daughter boards aren't removed it should be fine.
So the original ram is now socketed.
Will give it a try to see if it still stops after two rounds with the 9111 ram in and then it will be all ready to go back.
Lurch666
21 (100%)
4,517CR
virtvic said:
I bet one of our resident 6502 geniuses could alter that code to make it multi loopable…
While it's possible would it be worth the effort for this game since as far as we know it's the only one in existence?
It would be cool to find another conversion like this to compare with it could be that either no others exist anymore or this was a prototype and the only one ever made.
Lurch666
21 (100%)
4,517CR
PCB on it's way back to Body Pop now.
Before I sent it I remembered I promised a gameplay video but forgot all about it so made one today.
Notice when I put the coin in the game just freezes but if you look carefully you can see the '1' in the top right corner indicating a credit.
Only lost one life and managed to do the two loops after which it just jumps straight back to demo mode-it also does that when you run out of fuel or lives,no 'game over' or anything like that.
Lurch666
21 (100%)
4,517CR
That kinda looks cool.
Glad it made it back in one piece and works ok in your machine.
Lets hope someone on here who's a monitor ninja can tell you it's just a simple tweak to get that monitor working properly.
Body pop
24 (100%)
1,266CR
Cheers Sam you were right again .
Just need to get some coloured strips for it now
Anyone know where to get them ? The originals are there but are a bit warped
Also lurch ,are those five pots for the different sounds ? Can you remember which for the low fuel by chance ,to turn it down :)
Lurch666
21 (100%)
4,517CR
Great pictures.
It looks great running in the actual cab.
Glad this has all turned out well and you have the cab fully working.
No idea on the pots since I would just adjust them all at the same time so you are going to have to experiment a bit.
As for the coloured strips couldn't you just get coloured acetate sheets from an art/crafts shop or ebay and cut them to size?
Body pop
24 (100%)
1,266CR
Cheers lurch .yes I’ll experiment with those volume pots
I thought I had it right until I went low on fuel and woke the neighbours up lol
So that’s what you call that plastic stuff . I’ll look it up ,now I know
