Defender Resets
petercasino
212CR
Hi,
I've recently bought a non-working Defender. I've reflowed all of the connector pins, replaced the CPU board connector with a Molex connector, reseated the ROMs and replaced the RAM. This appeared to fix the game and I managed a couple of hours of trouble free play out of it :) However, it's started randomly saying that there is a RAM error. It's generally from within a game. I've measure the voltages at the RAM chips and they are: -5.12, 11.59 and 4.72. Are these voltages ok? I've got a power supply rebuild kit on order. Is there anything else that might be causing the problem?
Cheers,
Mike
Hurray Banana
2,756CR
When I was having reset and ram error problems with my robotron it eventually turned out to be low voltagetat the ram chips caused by poor joints on the power connector on the cpu/ram board. Once this was tidied and re flowed the voltage was stable.
I'd start by checking the 5v at the ram chips. If it's low check the header pins. If they are ok check the voltage at the power supply
philmurr
48 (100%)
2,374CR
There's a 10% tolerance on the power supplies so 4.72 is within spec. But I'd be tempted to double up the 5V cable to see if that makes a difference to the 5V level at the RAM.
Other than that, even though it's saying a RAM problem, reseat the ROM board ribbon cable as I've seen that give "RAM failures"
tb lilley
5 Star
1,686CR
As said, +5 is a bit borderline.
A simple mod to make the +5 adjustable is to remove one of the resistors on the power supply board (R26?) and replace with a 10k pot.
Here's one I did a while back: linktb lilley2014-11-30 19:17:38
petercasino
212CR
I've just checked the voltage at the power supply and it's marginally higher (4.77). I'll try re-doing the cpu connector pins and double up the 5V. I've just switched it on and it goes into the game but shows a load of vertical bars, doesn't look good!
@tb lilley, will lifting the leg of R10 make the voltage slightly higher?
petercasino
212CR
I'm going to install a 5K pot this evening. Is it safe to set the voltage at the power supply without any of the boards connected or does it need a load?
david_orton_2000
Green Mario
344CR
Do a Switcher conversion, much more reliable (try not cut the loom), I made my own convertor lead.
Damn Linears on those can go badly over voltage, etc.
Also, change the 4116 Ram (which cooks) to 4164 if you can (check Dave Langley's site).
Replace all ribbons and buzz them out.
Indeed re-flow all molex connectors. :)
Judder
1,009CR
tb lilley said:
Looked again, think it's a 5k pot at R2.
Hey TB - been meaning to ask can you remember where you sourced that 5K POT that is nicely the same gap width as the resistor at R2?
I bought a couple of the 'square blue trimmer' ones to do the same but they don't fit anywhere near as well...
Judder2014-12-01 16:20:33
Hurray Banana
2,756CR
Dave only problem with the switcher is the cmos doesn't always save properly, because of the quick voltage drop on the switcher.
4,058CR
If it's a linear supply then it needs to be under load.
Despite what specs the particular RAM chips may or may not have, 4.72v is LOW. Get the voltage up somewhere near 5v and I think your resets will go away. If it is only voltage at least, if something in there is on it's way out and failing under load then that might be a different matter.
Get the voltage somewhere near right first though.
tb lilley
5 Star
1,686CR
Sorry - really no idea, it was a couple of years ago now.
tb lilley
5 Star
1,686CR
Yeah, I hear that. Personally I don't like to use a switcher. Even when really nicely done with an unhacked harness. CMOS issues already mentioned. But its a bit more fundamental with me. I get hung up on using original hardware as it was designed way back in the day. So ... my Defender has had a fully rebuilt linear board. And new connectors all round to improve things further. Plus all pins reflowed and cleaned. And I'm still running 4116. So I've done everything I can to keep things up and running on original spec hardware. The cab hasn't put a foot wrong in 2 years and gets run pretty much every day of the week. If things go tits up then fair enough, I'll have to deal with it - but I've done what I can to manage any sort of 'risk'.
All personal preference though.
petercasino
212CR
Ok, I've installed the pot and now the voltage at the ram chips is 5.01V. I've reflowed the connector and doubled up the 5V. The machine does it's self test then shows the screen below with text I can't read. If you press advance it does that again. Though one time it actually started a game - very bizarre!
https://www.dropbox.com/s/4vcrwev54iblave/IMG_1832.JPG?dl=0
Any ideas what I should look at next?
BTW thanks for all the help.
petercasino
212CR
When you first switch on 4 lights. Then whilst it's testing they stay off, then all 4 flash twice. The game is starting now, but still has those strange vertical bars as shown in the picture. I've just re-plugged in all of the connectors...
