Defender Resets
petercasino
212CR
I've left it running for 10 mins and you can actually play the game but the screen has those vertical bars shown in the picture. I've noticed that LED's 3 and 4 have now lit.
tb lilley
5 Star
1,686CR
The 4 lights flashing twice indicate that the ROM and RAM are passing self test.
In addition to the advice above, there are other diagnostics that you can run.
See page 3 onwards of this: link
But before doing all of that, try wiggling the cable that connects ROM board to CPU board.
tb lilley
5 Star
1,686CR
Suggests either ROM or RAM fault. Try the diagnostics linked to above. Should narrow it down to one or the other and ID the chip.
petercasino
212CR
Ok, checked the roms and they appear to be ok. The game still boots and I can play a game, but it still has the jail bars. I'm wondering whether my ram is the problem? I think that seems to make most sense as all the tests are passing and the game is working but the graphics are screwed up. This is my first arcade repair and it's very confusing!
tb lilley
5 Star
1,686CR
Did you run the diagnostics? Wiggle the ROM to CPU cable?
Try taking ROM 3 out of its socket. Clean legs, then reseat. Look up the code on RAM fault table for lights 3+4 and do the same. Also, swap that RAM chip for any other on the board and see if the fault code changes.
Don't give up just yet. Reckon your pretty close.
petercasino
212CR
Code:
Yeah, I'm sure it's close too… Yes I've wiggled the ribbon cable and cleaned/reseated ROM 3.
Code:
I went through the diagnostics but I couldn't read the error codes because of the jail bars!
Code:
[code]The led error codes are listed here:
Code:
http://www.mikesarcade.com/cgi-bin/spies.cgi?action=url&type=info&page=DefenderErrorCodes.txt
Code:
It's saying that the ram is bad in bank1:4N, bank2:5N, bank3:6N How do you map that back to
Code:
the actual pcb as there are no labels?
[/code]
tb lilley
5 Star
1,686CR
The screen doesn't show the error codes, they need to be read from the ROM board.
So, you're in diagnostics. You get to the RAM test - if you have an error, light 2 will light and stay lit. Press Advance, with Manual Down. Then either LED 1, 2, or 3 will light. This indicates if the error is at bank 1, 2, or 3 of the RAM. Press Advance, with Manual Down, and the lights will change as per the error table. If the lights are 3 & 4 then your fault will be either 4N 5N or 6N. But to narrow it down, you first need to identify the bank.
How to translate 4N 5N 6N into locations. See page 3 of this: link
philmurr
48 (100%)
2,382CR
One other thing you might want to try is (when you get the 2 LED's appearing), press the reset button on the CPU board. It does what I'd call a "soft-reset" - it does exactly the same reset as when powered up but it doesn't remove power from the board which can give slightly different results from full power up.
The RAM chips (if faulty) may still be in the same failed state and the initial self-test may give more information. After the rug pattern, make a note of what the LED's on the ROM board do and report back.
petercasino
212CR
Ok, I've tried the soft reset above once the 2 leds appear and it does the usual reboot then the 4 leds blink twice and the game starts up (but with the jail bars).
I've run the rom diagnostics as described in the manual and the 1st led blinks twice which means that the ROMS are good :)
I'm now running the RAM test which shows the random pattern on the screen, it's been going for 10mins and still not finished - is that correct? How long should I leave it?
4,058CR
I believe it goes forever until you stop it. If it was going to show a RAM error it would have done by now. Not that I know how it shows that!
Have you got your voltages up to somewhere reasonable yet?
4,058CR
Sorry, missed that - thought we were still talking about low voltages
tb lilley
5 Star
1,686CR
When you ran the RAM test - did any LEDs light on the ROM board? If LED 2 blinks twice, the RAM test has passed. If LED 2 lights and stays lit, then the RAM test has failed.
petercasino
212CR
None of the LEDs lit during or after the ram test. The next test ran and led 3 blinked twice. At what point should the LEDs light during the ram test?
