Right, bumpety bump!
I've spent most of the summer so far working on the house and garden but I'm aware that people are waiting on me for board repairs so I decided I better pull my finger out on this so I can get it off the bench and sent back. There were two remaining problems.
1. The high score saving doesn't work
2. The whole picture is shifted to the left by about 1/2"
So the main thing I wanted to do today was investigate the picture. Is it my test monitor, which isn't the best in the world, or is it the board? First though, the high score saving. Simple. New EA-2055 RAM and it now works. Confirmed by trying the old EA-2055 in my known working PCB.
While testing that I noticed that the explosion sound wasn't right. I wasn't 100% sure that it wasn't my AR2 board but I ploughed on. Sounds are generally pretty simple on Asteroids / Asteroids Deluxe. AD is slightly different because most of it is handled by the Pokey, but explosion and thrust are still discrete. So I went all over the explosion circuit and to be honest, I couldn't see anything wrong. All the frequencies were there, activity was everywhere it should be and everything appeared to be happening at the right times.
SO, I tackled it the grunt way, chip by chip with the logic comparator and every chip involved bar 1 compared as good. Now the way the logic comparator works is, if a chip says it's good, you can take it at it's word and it IS good. If it says it's bad, it may not be, there may be external factors at play. I also know that 74LS74 chips are one that it can't always detect properly so when it said the LS74 in the explosion circuit had bad outputs I didn't know whether to believe it or not so I desoldered the chip and tested it in my eprom programmer. Sure enough, it was bad, but in a way you'd NEVER have found without desoldering it, or possibly using a logic analyser. The outputs were both toggling, and were both opposite each other, but the state was negated to what it should be, so when they should have been low, they were high and vice versa. Like I say, you'd never have found that!! Replaced the chip and the explosion sound was fixed.
All I've had time to do on the picture is test the board in my cab and confirm it's the board not my test bench monitor.
So does anyone know what would cause the entire X axis to shift by about half an inch please?
