Midi cab plans
2,272CR
I decided it was easier to measure everything I could, that way you can see how it all fits together.
This is a Taitel T-83 cabaret. Overall cab size is 550mm wide. The neckboard is a few cm from the back door and the chassis is mounted on the side of the cabinet. It wouldn't fit with the cage on.
Monitor wood measurements.
cools
I joined ages ago honest
19 (95%)
804CR
Cheers man. Wish I'd seen that before, its practically what I've ended up with anyway!
Will adjust accordingly, I don't want an exact clone but that gives me enough to work with.
cools
19 (95%)
804CR
Many thanks for the dimensions so far. Design is coming along. Looking a bit more like a classic Australian style lowboy cab. I've made the marquee section nowhere near as deep as the Taitel because the cab height is significantly shorter.
Other than the sides where it's not so important, everything is exact millimetres, and I've tried to round to the nearest 5mm everywhere. All done with no mitres so getting the plans CNCed should be a doddle.
It should fit a 20" Hantarex Polo or similar horizontally or vertically.
Need to do a bit more checking and add holes for the usual stuff, then go over it and place all the dowels.
Contemplating doing it with a flat top. The benefit being you can shove stuff on top of the cab. The downside being the marquee is then perpendicular to the ground unless some parts are mitred. Not sure right now.
cools
19 (95%)
804CR
Nope, although I do get to wear that hat when it suits.
I just made a list of all the bits I liked in different cabs and appropriate properties and put them together :)
Hoping I'll finish this soon so I can prototype it.
urbanledge
95CR
cools said:
no mitres at all. Not sure exactly how well some of the joins between panels will work
Have you ever heard of a kreg gig?
Its the absolute dogs bollix if you can get it predrilled and use the correct screws for the timber.
unbelievably strong join at 90 degrees with no glue/battons.
They look like this
You use a machine to drill the hole then drive the screw home.
urbanledge2014-04-24 08:09:28
cools
19 (95%)
804CR
There are no joins like that. I'm referring to the non 90 degree angles that give the cab its shape, like where the roof meets the back.
urbanledge
95CR
You could use them to fix every thing onto the gables
then worry about the non 90s at the end.
I'm using the gig system on my current build and will never do woodwook with out them again I reckon!
cools
19 (95%)
804CR
I'll stick with dowels methinks, bit more idiot proof for sending plans off for cutting.
Got most of the detail and internal work done. I'm not sure I'm entirely pleased with having a flat top, I may try angling the sides whilst keeping the marquee area flat and see how that works.
EDIT: better
Milky
1,037CR
I quite liked the sloped top, it looked very cool - if its just from a storage perspective, you could just pop a shelf up above where the cab will sit?
cools
19 (95%)
804CR
Yeah, I might try reverting that part. Think I'll keep the lip at the back though, I quite like the idea of not losing stuff down the back of the cab.
Milky
1,037CR
Yeah, that's an important addition to avoid the awkward "aargh! my car keys!!!" moment
Beaps
373CR
cools said:
Just picked up a brand new in box HP s9500 19" PC CRT to decase for this. :D
Loving this tread....
So you going with a PC monitor, would you still be able to run it in low res to get scanlines or are you not fussed?
cools
19 (95%)
804CR
It'd be an emulation cab so fake scanlines (or real hardware scanlines running at double frequencies).
As it's a CRT if you just run at a doubled resolution with fake scanlines it looks authentic, albeit a tad crisp on a monitor that's capable of clear 1600x1200 natively.
Tabletops with LCDs rather than small PC CRTs in I don't understand at all - the CRT would look infinitely better and have perfect viewing angles...
ZedEx48K
8-Bit
1,425CR
There's a pretty easy way to cure that and soften the image with pc monitors though*, take the back off and there's 3 pots on the lopt, brightness and H & V alignment, just offset the last two a little till you are happy
* Not my fault if you kill the monitor or yourself
ZedEx48K2014-04-28 16:46:14
cools
19 (95%)
804CR
Defocussing the horizontal might be an idea, I didn't know PC monitors had a separate H and V focus. Definitely don't want to defocus the vertical though, that'd mess up the scanlining ;)
