Naomi Pi 'WiPi Netbooter' - compatible with Pi 34
Copperband
56CR
Now I’ve really messed things up!
I went to update the WiFi settings which needed a restart, for some reason it never restarted and now I have intermittent red LED flashing on the Pi and it won’t boot at all
chunksin
21 (100%)
731CR
Rewrite the image file to the SD card, sounds like it has corrupted which might explain the progress bar. If it happens again, try another card
Copperband
56CR
Just reading about the open JVS function. Am I understanding this correctly that I get an io board, somehow connect an xbox controller and could then play something like club kart without the wheel set up?
chunksin
21 (100%)
731CR
OpenJVS replaces the JVS IO board with an RS485 to usb adapter and you can use any controller that works on the pi for example Xbox and PlayStation controllers, Wiimotes for shooting games and some Logitech wheels for driving games. You could even add a jpac or generic usb zero delay board if you wanted.
You need an FTDI chipset, this is the one I use: https://amzn.eu/d/6UKDjkG
Then chop up any usb cable and wire it up as per the instructions on the OpenJVS GitHub, you need a 1k ohm resistor or 4 X signal diodes.Chunksin2022-09-19 20:37:08
Atssa Irouma
6CR
Hello..
Super impressed with the great masterpiece.. wipi netbooter.. chunksin.
I am enjoying 6.1-4 image.. but it looks like 6.1-9 is the latest?
Where is the latest image? Sorry for only question..
Thanks, Kim.
14CR
Hi guys,
After multiple attempts I can't find the network WiPi-Netbooter . Any tips please?
The WiFi of my Pi 3b+ works. I tested it with a Pi OS.
I extracted the part 1 of the 14rar files using 7-Zip and I wrote the img file WiPi6-1-4 with both Etcher and Win32DiskImager to a class 10 SanDisk SD card, but luck!
I don't know what I am missing?
