Outrun Deluxe (Turbo De-conversion) Restoration
clarkey
94CR
If anyone does know the RAL as above for the base would be great if not will take a bit to get color matched.
Still struggling to find a screen :( , although a member here is going out of his way to try and help me find one so that is great!
Little update.
The power Supply & Amp Board
Stripped it down cleaned everything checked fuses, solder joints etc. On the whole was in really solid just dirty shape. Seems the op had never had reason to touch it so no dodgy wiring mods.
After.
The AC Unit
Some very odd wiring here, this was caked in dirt, this "before" pic is actually after removing one pinball a dead something an air hockey puck and a mountain of dirt fluff and other "things"
The mains wire was terrible and frayed so have removed, it also had another wire soldered directly to the back of it as it entered the unit that fed up to I assume a 240v screen they had used, removed all that wiring.
I have ordered a new cable snag and will replace the AC wire, this will mean I can then test the cab with no boards in just to see if fans come on and get some voltages etc. Will be ready with a fire extinguisher :D
I will strip this board again later and paint or powder coat it once I know the color details.
Before
After
clarkey2018-08-02 12:18:16
clarkey
94CR
Just want to say a huge thanks to Mykill who sent me the
below boardset and wheel center decals absolutely free, much appreciated
and will be a big help with the restoration!
clarkey
94CR
Flinnster said:
Seriously cool - as always
Cheers, I am making good progress, lots of it is just cleaning cleaning and more cleaning at the moment but will be working on some more interesting / worth photographing bits soon.
clarkey
94CR
Stripped and rebuild the steering with a set of giz10p's gears. Just need a C gear to complete.
Cleaned up the first of the side art, lots of damp closthes wet wipes and magic erasers. Really pleased with how it's come up.
nurtuo
326CR
Now that sideart clean up, that looks amazing.
And you will not regret those metal gears too,
just get some of the correct grease on them and they will feel great,
and last forever.
Keep up the good work and it will soon be all finished.
clarkey
94CR
Last update for a week or two as building work is starting on the garage.
Angle Mech
Before
During
After
Motor and linear drive.
Before
After
Greasy and grose
Not so Grose
Power supply back in, all tested and voltages looking good.
Before
First fresh paint.
After
First day I opened the covers
Lots and lots of cleaning later!
All wrapped up safe while the work is completed around (and under it)
clarkey2018-11-05 17:21:27
tin
657CR
I'm very intrigued about your re-spraying there. Just doing it bit by bit with rattlecans? do you just mask off and go for it?
clarkey
94CR
Sanded back smoothed out etc, then primed with a zinc etching primer then grey over the top of that.
It looks good on the inside. Not aure about the larger panels yet, will probably try the above and see how it looks. The finish on the base is pretty basic anyway.
tin
657CR
I decided to leave mine because of the mammoth effort of stripping the lot and getting the whole thing sprayed in one go, but if this method works - basic or no - I might copy it! Especially cos someone painted mine blue in the past :(
clarkey
94CR
onfre said:
Very nice work on that fantastic cabinet! This is the best one you're right!
Thanks, it’s a lot of work but hopefully will be worth it. Have made lots of progress will update with some pics in the next day or two.
clarkey
94CR
Work has been progressing on the Outrun. As it was left above, I have been able to get on with some parts as I converted
the Garage where the outrun was kept into an office / games room.
During the conversion the floor was raised, this posed some challenges.
Never dead lift an Outrun.
While the building work was going on I worked on some parts of it that I could within the house.
The drive board and light board where filthy and the metal bracket they attach to had some serious rust issues so a good clean & paint etc and it's looking better.
Before
After
The PCB's are Turbo converted, I doubt they will work without some re-work but they were so dirty I at least wanted to get them cleaned up before I even test them and hopefully then de-convert them. Used a isopropyl alcohol and distilled water clean method I found on youtube.
Before
After
clarkey2018-10-05 18:23:01
clarkey
94CR
Now the plastering is done in the garage I can crack on with all the painting (before I decorate the room)
I have started with the base first.
I first washed the whole thing removed all the years of grime etc, then I electric sanded the entire thing (with a very good face mask on!)
At this point it mostly looked as per the below.
I then sealed the base with a Zinc etching primer, hopefully this will stop it corroding for a good few years.
Once that was done I added the top coat and then four layers of clear to try and give it a bit of strength. I did the coin tower coin door etc at the same time.
Before
After
Before
After
Few more pictures of how it looks.
Have now wrapped it all up so I can prep and paint the fiber glass, I finally feel like I am getting somewhere.
clarkey2018-10-05 18:24:21
