R Type 2 stuck inputs
virtvic
The Cabaret King
21 (96%)
2,013CR
I snipped out the LS244 and socketed and fitted a new one.
Still the same
DOWN isn't on all the time now, but you can't go up at all.
Fantazia2
2,246CR
Have you got a logic probe to see whats happening at the input pin on the LS244 when up is pressed, I think it should be Logic High normally and then go low when up is pressed.
It could possibly be the 244 you've replaced is faulty as well if the logic ends up being correct at the inputs, might be worthwhile probing the down input at the 244 when up is pressed to see whats happening there as well.
I think youve proven it shouldnt be anything past the 244 as Up was working before, or was it. You said that pressing up stopped it going down so it could either have been both up and down were activated cancelling each other out or pressing up turned off down.
Anyway I think the first thing to do is probe the inputs for up and down on the 244 to see whats happening there when pressing up and then go from there.
virtvic
The Cabaret King
21 (96%)
2,013CR
The 244 is going LOW on the relevant pins when directions are pressed, except pin 11 (UP), which stays HIGH (as it did before) The replacement 244 is brand new and I have another, which works the same. I doubt the 244 is at fault (or the old one, it seems) ???
5,661CR
Is the track broken? Could it be the 244 isn't receiving the input? Can you force the input LOW to see if it then goes down?
Fantazia2
2,246CR
Right having a think about it, the pins are pulled high by the resistor array when you are not pressing a direction, so since up is not activated then the 244 must be getting voltage from the resistor array so that track between the 244 and resistor array must be ok, so...
Check resistance from the pin on the 244 to the edge connector for up, this should be a direct connection with a 220ohm resistor in it, i.e. the ones you soldered on to fix the incorrect resistor array.
If you get no continuity between those two points then there lies your issue.
How are you testing the inputs, its not going to be something silly like a loose ground wire or failed switch on whatever you are using.
EDIT: Just re-reading the thread and saw you said you plugged your controller into player 2 port and UP wouldnt work on that either, is it your controller?
Fantazia22018-02-02 21:54:20
5,332CR
Did you try pulling the pins to 0V using a resistor?
If that works then it might be a track, might be your joystick, might just be that the JAMMA connector needs a little Brasso.
virtvic
The Cabaret King
21 (96%)
2,013CR
It wouldn’t be pulled low.
The tracks are fine.
The controller is fine - checked the directions on a working Major Title test menu (and a working cab)
